Hi guys, I am looking for a diff, for my r1 powered Fiat 600
I have limited space, the engine is mounted at the rear, with the drive pointing at the front.
My plan is to use a rwd diff, turned upside down.
Witch, readily awailable diff is the shortest ?
Ford 7 inch, Freelander , BMW or other ?
A lsd is a given, so it needs to have that awailable.
HP
The MX5 different seems to be quite short from flange face to outputs.
Quick look on eBay and I thought MX5 too.
Ignoring the power capeability I wonder what one off a small 4x4 would be like for instance a Panda?
ford sierra 4x4 front diff short, because is front you dont need put up side down. but i dont know power it can handle.
Also you can look others front diffs, some cars have smalls diff like this
https://www.ebay.com/itm/1990-Suzuki-Quadrunner-250-King-Quad-300-Good-Front-Differential-Diff-Final-Gear-/401130179069
[Edited on 21/1/18 by fregis]
Thank for the help guys
I have found a few VW front diffs, that look good, will order one and see.
HP
