Want this look on my straight-6 BMW haynes roadster but need to accomodate 2x O2 sensors (one on each bank of 3 cylinders), any ideas?
Seems ambitious, who are you paying to make that for you?
I'm pretty sure the O2 sensors wouldn't work right. Each one takes a reading of the mixture for those 3 cylinders and adjusts the fueling
accordingly. You could line one up just after cyl3 and that may work OK but the other will be reading all 6cyls so I don't see it working right
and may not even pass emissions.
I'm happy with my 6-2-1. Works correctly, sounds amazing and cost peanuts to make
[Edited on 27/2/18 by Nickp]
Why do you need 2 o2 sensors? I assume you are on aftermarket management? You should be fine running one o2 sensor that reads all 6
cylinders.
Not sure why there would be an issue with emissions...
Originally posted by theduck
Why do you need 2 o2 sensors? I assume you are on aftermarket management? You should be fine running one o2 sensor that reads all 6 cylinders.
oh i see, i assume the OEM ecu has some kind of trim table then to adjust for the banks running differently. In which case you could probably get away with running them both reading all 6 cylinders. In fact, you could possibly even get away with running 1 and splicing the signal to both inputs on the ecu. Or switch to aftermarket management and just run 1 wideband
That is certainly a rather tidy looking fabrication!
Do you know what car it's on?
I'm guessing something where the exhaust system is fairly visible and it enhances the overall look of the vehicle.
It does look good but I agree probably not sensible due to the likely cost and issue with the O2 sensors. This exhaust system was on a V12 with this
exhaust mirrored on each side.
The OEM ECU had 4 O2 sensors - 2 before and after the cat on each bank of 3 cylinders. The ECU has been altered to delete various things including the
post cat sensors to make the engine usable without ABS etc.
These engines with dual-vanos (variable valve timing on both inlet & exhaust) are tricky setting up with aftermarket engine management.
[Edited on 27/2/18 by craigdiver]
It's also a dodgy header design - it's basically just a log with long runners.
oh lovely....if your are a fan of chitty chitty bang bang
Original post is how I imagine it would look fabricating it myself, how it would actually turn out..... ;-0 :-)
WTF take that for an SVA....
reminds meof this work of art
Is that the beast that was being built on an old London black cab chassis, with two Jag straight sixes in it ?
(I lost the link to it, was on Garage Journal)
Hi Craig, here's what my M52 exhaust ended up like... I wanted it to look like your original post but there are so many reasons why it
couldn't exit straight out of the block...
Regards,
Chris
Originally posted by CTLeeds
Hi Craig, here's what my M52 exhaust ended up like... I wanted it to look like your original post but there are so many reasons why it couldn't exit straight out of the block...
Regards,
Chris
Hi Craig, I do have the 2 x pre cat sensors fitted...
I haven't been through IVA yet, and at the moment it's running a bit rough. I'm hoping it's just a sticky ICV or similar
though.
Chris
I haven't been through IVA yet, and at the moment it's running a bit rough. I'm hoping it's just a sticky ICV or similar though.
Chris
I wish! No, I had to hand a large sum of money over to a professional.
Chris
Do you have a cat in there somewhere?
Yep. There's a 300 cell sports cat in the silencer.
Chris
Chris
Not at all. It was an eye watering 1500+VAT!!!
It's all in the labour really Craig. The parts altogether probably came to less than £500 but he did have the car for 9 days. Being such a fiddly
design it took him a while. It was though in my opinion a fair price for a good job. I just wish I could weld stainless.
Regards,
Chris
It's all in the labour really Craig. The parts altogether probably came to less than £500 but he did have the car for 9 days. Being such a fiddly design it took him a while. It was though in my opinion a fair price for a good job. I just wish I could weld stainless.
Regards,
Chris
