Hi all, new to the forum and after some advise so I hope I'm posting in the correct place.
I'm after an omex 200 although would consider an omex 600 and later look at going down the injection route,
Can anyone advise the cheapest place to purchase an omex and loom for a zetec.
Thanks in advance
You do realise an Omex 200 doesnt do fuel injection?
Hi yes I'm fully aware of this, currently running carb but thinking of possible injection route further down the line, thanks though
Have you considered the Nodiz Pro? available from Danst Engineering, I bought mine from Chester Sporstcars full loom and mapped so was just plug and play
Hi I can't say I have but I'll have a look into it, thanks
i use Megajolt for the ignition only on my zetec as im running carbs. Works very well, but you do need to run the Ford EDIS system with it, whereas you dont with the Nodiz system
