Can anyone tell me how high off the carb a Weber LP1000 linkage sits?
The Zetec in our Seven is sitting a little higher than normal due to a modified sump meaning we have limited room above the carbs. Also dont think an
underside linkage will work due to the cross rail supports.
Ideally a Mangoletsi linkage would work but looking at option as cost and stock are prohibited.
