compact mx5 inlet manifold
cliftyhanger - 11/10/18 at 11:00 AM
Just having some (probably bad) ideas. But does anybody make a compact inlet manifold for the mx5's?
Thinking something like the zetec ones sold by kitcarparts, still wanting to use the std throttle body etc etc.
A search has not turned anything obvious up (yet)
Ta.
Mr Whippy - 11/10/18 at 11:27 AM
probably easier and cheaper just to tackle the issue which is making you think you need a more compact manifold, they seem quite compact as is. Is it hitting the chassis? if so how about moving the engine off centre to make more room?
cliftyhanger - 11/10/18 at 12:09 PM
A friend wants to put an MX5 into a standard atlas van. Height seems to be a problem. His plan B is a lexus V8 which is an easier fit. But a van that had about 40bhp when new may not like all those extra horses. The mx5 was only triple the bhp.... (scary enough for something like the van)
nick205 - 11/10/18 at 01:01 PM
If it's going to foul the bonnet can you not get a bonnet with a bulge to accommodate it?
cliftyhanger - 11/10/18 at 01:16 PM
You sit on the engine cover! Well, sort of...
Charlie C - 11/10/18 at 02:07 PM
Mx5 MK1/MK2 engine are quite tall changing the manifold wont help that.
If you want a more compact inlet have a look at ITB's http://danstengineering.co.uk/ or jenvey are worth a look.
The problem with ITB's is although they dont extend so far forward or up they stick further out to the off side.
[Edited on 11/10/18 by Charlie C]
cliftyhanger - 11/10/18 at 04:46 PM
I guess the obvious answer is to make one.....not exactly rocket scince, and even if the runners are not optimal the loss of a few horses won't be a disaster. The vans are cute, but make a VW T2 look like a go-cart to drive
