I currently have open 7" diff with push in shafts and drums converted to discs with bolt on brackets installed in my MK Indy.
I've just bought a Sierra 7" LSD that I'd like to fit. The new diff has bolt on flanges so I know I need new driveshafts.
Looking on eBay it seems there are different length driveshafts. Does anyone know how I work out what I need?
Does anyone have any?
On the Scimitar (7” push in with drums) you can just remove the inner CVs and stub shafts and fit bolted type CVs?
Thanks, I have been reading a bit about making hybrid driveshafts can can't quite work out if the removal of one sliding inner joint is a
problem.
The car is likely to see a fair bit of track use.
Does anyone have long term experience of how well they last?
can't tell you how long they'll last - but most people that use them don't seem to have too many issues (unlike a tin-top its not like
most people drive 10k+ a year in a seven)
the alternative will need you to get the bolt-on hubs, stub axles and flanges
(and I don't know if your drums will fit these either as all the sierra's with bolt-on shafts used rear discs too)
rear axle bits
Mine's been fitted for 5 years without problems. Only 6000 miles - but that does include a couple of test days at Curborough. I had the same setup on the sprint car until I picked up a Quaife.
Originally posted by mcerd1
rear axle bits
Thanks. How did the Viscous and Quaife units compare?
Prices have dropped so about £800 by the time it's fitted into my final drive unit.
If I put in a Sierra unit and can make up some driveshafts as described above I think it could be about £350?
Not sure if its worth the extra?
New Quaife or s/h Ford - never going to win on finances alone
New Quaife or s/h Ford - never going to win on finances alone![]()
