Can anyone tell me,
Are the engine - bellhousing bolt patterns the same on the BOA / B engines and the 3.0L Essex V6?.
Thanks.
Pete.
[Edited on 16/11/18 by r1_pete]
I am sure they are all the same, but I bet Burtons website will give you a definitive answer;
https://www.burtonpower.com/
If you cannot find the info online, I am sure they will be able to tell you via a phone call, their staff are very friendly and knowlegable
[Edited on 16/11/18 by slingshot2000]
No the cossie v6's are cologne based that are totally different to the Essex v6
Bellhousing for Essex & Cologne are the same pattern
You can fit Type 9 which has removable bellhousing or MT75 which is built in
V6 bellhousing are different to inline as are the gear ratios and input shaft lengths, the top 2 bolts closer together than inline bellhousing.
Cheers guys,its for a Scimitar, I intended doing a V8, but, bought a car with interesting history, so thinking about a better engine which doesn’t
involve cutting the car.
If the Cologne is the same bell housing pattern, my best option I think is an injected 2.9.
PPC magazine have been doing a similar conversion if that's any help?
Aj30 would be better
The 2.9 V6 used by Oval Superrods uses a a 38DGAS on a modified manifold and I’ve seen 200bhp and similar ft/lbs which ain’t bad.
The Granada Cossy 2.9 would also be a good base
Good luck with the build
Originally posted by snapperBellhousing for Essex & Cologne are the same pattern
Bellhousing for Essex & Cologne are most definitely NOT the same pattern.
can confirm...essex and cologne do not share the same bolt pattern.
an interesting upgrade, still remaining the cologne bolt pattern, is the 4.0L ford explorer engine
