Hi everyone, the engine I’ve built for my MGB GT is basically an R500. Looking at around 250 to 260 bhp. I’ve seen these Bosch injectors for Astra vxr
0280156280. I know green giants work but there seem to be a lot of fakes about and the Vauxhall’s ones are easily obtained at a good price. They are
470cc/m. Would they suit or are they too big and will give poor idle?
Many thanks for any input
Being a modern style of injector of that size, they will idle perfectly well and they are more than adequate size wise. I have a used similar spec bosch and even larger denso injectors without issue.
Cheap oem,
pico sized injectors, Megane 225 around 440cc.
Full size Bosch, Focus Rs mk1 around the same cc. Both can be had for just over £100 for a new set of four.
Cheapest I found for 440cc used were subaru “baby blue” injectors. Under £50 a set.
Originally posted by itsawindupuk
seen these Bosch injectors for Astra vxr 0280156280...
I used Giant Whites for a while in mine, now I have 2 injectors per port which are standard Mondeo.
Thanks for the responses everyone. I'll order the vauxhall ones and put up a sneak preview of the engine
