does anyone know if CVH 1800 sump will fit a zetec engine ?
It'll kind of fit. The Sierra 1800 CVH bolt pattern is the same but there are 4 extra bolts in the Sierra so you'll have to drill and tap the aluminium housings of the Zetec at each end. It's not a perfect fit but if you can't get the aluminium Zetec sump welded you'll make it fit.
Nice one thanks for that
I heard this on another forum and thought if it could be done someone here would know for sure,the only reason i ask is that it may be a lot easier to
chop a cvh sump.
also i am not really interested in paying dunnels best part of £250 for a chopped sump since i want to do the zetec instal for that and a bit more
Just found some info on this at this very good zetec site.
http://www.zetecescorts.bravehost.com/
I heard this on another forum and thought if it could be done someone here would know for sure,the only reason i ask is that it may be a lot easier to chop a cvh sump.
Half the price of dunnels for the sump chop,so worthkeeping in mind.
