Exhaust noise
pmc_3 - 25/1/05 at 06:56 PM
Couldnt decide where to post this. Basically for the track day I am doing next month at donington, the car cant be over 98db.
I know mine is quite loud, so i'm a little concerned. Its straight pipe from the manifold all the way to a cherry bomb backbox (was a quick fix to replace a very holed one, but does sound quite nice ) Its a 2.0 pinto engine. Has anyone had there's noise tested and how did you get on?
Ben_Copeland - 25/1/05 at 07:00 PM
Put a nice lump of stainless steel wool in the exhaust, heard that lowers the noise a bit. Then wip it out as you go onto the track
[Edited on 25/1/05 by Ben_Copeland]
Peteff - 25/1/05 at 07:07 PM
Then watch for the black flag coming out. They're not stupid. Get a box to fit in the straight pipe, just cut a section out and clamp it in.
Northy - 25/1/05 at 08:42 PM
You'll then fail the drive-by test from the noise monitor (one of ours) fitted on the main straight!
They are keen at Donigton!
pmc_3 - 25/1/05 at 09:05 PM
You reckon it'll fail then?
Stu16v - 25/1/05 at 09:10 PM
Not unless you get the engine running!!!
(Sorry, couldn't resist...)
You have exhaust length on your side, which most Locosts don't have, and that will help. But I personally doubt that a small straight through cherry bomb will be enough to get on/stay on track at an average Donington trackday TBH...
pmc_3 - 25/1/05 at 09:20 PM
Fancy helping me push it round I had a feeling that it probably would fail
