Hello, I have a Mondeo ST200 prefacelift, the one with a separate tesioner for the water pump, and i'm strugling to replace the auxiliary drivebelt tensioner, because there is not enough room for fitting any conventional wrench or rachet in order to take out the tensioner bolt, so i wanted to ask if someone had any experience replacing this. Thank you.
