Can anyone confirm the offical capacity for the Dunnell sump on a silvertop zetec is 4.5L?
My engine is pushing out oil since changing it and i have a feeling that i have put too much in! The dipstick hits the bottom of the sump then curls
under, so is not really accurate enough etc to know where it should be. Time to drain it and measure it back out again
Yeah, I think that sounds about right. I'm sure I cant get 5 in my one.
Ah, I have a blacktop.
You could call Paul to double check?
[Edited on 14/9/20 by pigeondave]
Spoke to Paul this morning.....3.5 - 3.75L is what should be in there! Time to drain the sump!!
Is the black top different to the silver top?
I hope so
not really, he said they are all around the same capacity!
I'll find out one weekend soon
I can hear AdiT laughing from here about the above statement.
3.5 - 3.75. ???
Ive got a dunnel built Zetec here in workshop it runs 4.5 Ltr
can only go by what he has said to me, does seem a bit on the low side. Haynes quote 4.25L, so as it has been shortend and is not wider etc, would be about right?
Is the Dunnel sump actually unique to him or is it from somewhere else like Raceline?
Unique to him
He chops them and welds them up. At least my one is.
yep mine is a cut and shut, not a cast one like the Raceline offering
And the holes in the bottom of the sump don't line up with the bell housing.
I was told it wasn't an issue as the other 4 bolts are plenty strong enough.
