Engine: 2L Zetec blacktop
Apologies for the basic question, but can someone tell me what the "thing" is below the exhaust manifold and above the starter motor, sump
and engine mount.
It looks like some kind of pressed steel water jacket with an outlet pipe at the rear, bolted to the side of the engine block.
Regards
Sounds like the Crank case breather
Yep crank case breather. Its job is to separate the oil and air. It has a pcv valve that release the vapours into the inlet manifold to be burnt off
in the donor.
You have multiple options with what to do with it
[Edited on 25/11/20 by big_wasa]
I removed it, blanked it off with homemade plate and gasket. Zetec seems to run just fine without it after 10,000 miles.
ETA See old thread below
Linker
[Edited on 25-11-20 by Slater]
Linker
