Worryingly high oil pressure on Pinto engine
bumpy - 11/4/21 at 07:56 AM
Before being put into storage at the end of last Summer my car ran with normal oil pressures, generally about 50 psi when running hot.
For some unknown reason it now wants to run at 90 psi most of the time. Its like someone turned on a switch to just about double the pressure!!
I put in a new oil pump, two new filters, changed the oil from 20/50 to 10/30, tried two other oil gauges including a calibrated capillary gauge and took the head off to ensure no blockages to all accessible oil galleries.
Looks like I now need the experts. Please help.
cliftyhanger - 11/4/21 at 08:11 AM
Pressure relief valve stuck shut?
(I have zero Pinto experience, but all engines have a oil PRV to moderate pressure)
bumpy - 11/4/21 at 09:08 AM
Thanks, but as far as I know the pressure relief valve is part of the pump assembly, which was replaced in its entirety. Difficult to believe that both the existing and replacement pumps have the same issue
Does anyone know at what pressure the release valve operates?
rusty nuts - 11/4/21 at 09:15 AM
It will be a stuck oil pressure relief valve , it's the only thing to control the oil pressure
bumpy - 11/4/21 at 10:07 AM
jacko - 11/4/21 at 10:23 AM
Just a guess is the pipe over the cam ok
I know you say the valve is new but that’s does not mean to say it’s ok
Did you swop the pump like for like not a high capacity
Graham
[Edited on 11/4/21 by jacko]
Mr Whippy - 11/4/21 at 12:56 PM
First thing to do is confirm the oil pressure by fitting a test gauge. Most garages will have one. More often than not its the gauge is incorrect. If its an electronic gauge check the wiring and earthing.
bumpy - 11/4/21 at 01:14 PM
You must have missed that that has already been done (first post)
bumpy - 11/4/21 at 01:16 PM
Graham
Pump swapped like for like, but high pressure exactly replicated what was present on old pump.
And yes that spray bar was fully clear
[Edited on 11/4/21 by bumpy]
David Jenkins - 11/4/21 at 02:34 PM
That was my thought - it could be a faulty oil pressure gauge or sender. Can you scrounge one from somewhere, just to try it out? Doesn't have to be anything grand, or calibrated, just a cheapo gauge to see whether it still shows an abnormally high pressure.
bumpy - 11/4/21 at 03:00 PM
Still would like to know what pressure the release valve should operate at.
jacko - 11/4/21 at 04:10 PM
A standard oil pump works at 60psi at 6000 rpm a high pressure oil pump is 90psi
So I have just read on classic Ford forum
As a matter of interest where did you buy the new pump as I have just read burtons sell high pressure pumps
Graham
David Jenkins - 11/4/21 at 04:39 PM
You don't expect me to read the WHOLE post, do you?
Apologies...
bumpy - 12/4/21 at 08:55 AM
Graham
It was indeed a Burtons pump OP1
https://www.burtonpower.com/std-oil-pump-sohc-ford-pinto-e scort-cosworth-t25-op01.html
Still doesn't answer the question why a car that ran all last year at normal oil pressures should suddenly double its oil pressure when re-started this Spring, when absolutely nothing had been changed ?????
CosKev3 - 12/4/21 at 09:13 AM
Graham
Could well be a HP pump supplied by mistake?
And the old pump had a stuck relief valve?
CosKev3 - 12/4/21 at 09:15 AM
Have you stripped old pump and checked relief valve piston?
jacko - 12/4/21 at 04:31 PM
Looks like the only thing you can do is sump off and check the relief valve there is nothing else that I can think of to cause your problem
Unless some one can think of something else
Graham
jacko - 12/4/21 at 05:31 PM
I think you may have answered your own question it must be a stuck valve
Of cause I could be wrong
CosKev3 - 12/4/21 at 05:37 PM
It's the same with a brand new pump though?
bumpy - 13/4/21 at 07:51 AM
Old PRV was taken apart, and no sign whatsoever of it sticking
jacko - 13/4/21 at 08:13 AM
Well if you think it isn’t the valve I don’t know what it could be faulted oil gauge maybe but you say you checked that
Graham
r1_pete - 13/4/21 at 09:14 AM
Does the engine sound rattly as if its starving of oil? If so, something could be blocking the galleries close to the pump.
adithorp - 13/4/21 at 09:23 AM
Wasn't there some issue with Burtons oil pumps? Seem to remember something about the galleries not lining up properly that o read something about a while ago. Probably on a ford forum..
jacko - 13/4/21 at 02:40 PM
Did you put gasket past in-between the pump and pick up or pump to block ? If so it could have part blocked a gallery
[Edited on 13/4/21 by jacko]
steve m - 13/4/21 at 06:28 PM
@Bumpy
Can you repost EXCACTLY what has been changed on or in the engine since the oil pressure was around 50psi until now its 90psi
I have had similar problems on a xflow, when the Prv wouldnt open but was more around 70psi at tickover
bumpy - 14/4/21 at 03:02 PM
Engine sounds fine - no rattles. And I think if there was a blockage close to the pump then the gauge would read low not high.
[Edited on 14/4/21 by bumpy]
bumpy - 14/4/21 at 03:07 PM
Any gasket paste was used VERY sparingly, so no chance of it blocking anything.
bumpy - 14/4/21 at 03:10 PM
Originally posted by steve m
@Bumpy
Absolutely nothing aside from the fact the car sat idle over a Winter lay up,
All other changes were made in an attempt to identify and rectify the abnormal behaviour in oil pressure.
bumpy - 14/4/21 at 03:25 PM
Considering the pressure relief valve.
Old pump and new pump gave exactly the same readings
Specs say the PRV should open between 58 and 68 psi.
I guess that it is opening OK, and that pressure shown above this is because the pump must be designed to give some oil pressure within the engine even then. If this were not the case then nobody would have an oil pressure reading of greater than 68psi ever.
adithorp - 14/4/21 at 06:19 PM
The prv opens when the pressure exceeds the specified amount. It then maintains that limit pressure. The only way you can get higher pressure is if it doesn't open/operate
rusty nuts - 14/4/21 at 06:47 PM
Agreed
You can lead a horse to water?
Mr Whippy - 15/4/21 at 06:24 AM
“ When you have eliminated the impossible, whatever remains, however improbable, must be the truth”
bumpy - 15/4/21 at 07:04 AM
So are you saying that any pinto engine that shows a pressure reading higher than 68 psi (which is the upper spec of the PRV) has a fault?
If this is the case I suspect there will be a lot of worried owners out there.
mcerd1 - 15/4/21 at 10:37 AM
^^^ basically yes
although there is bound to be an error of a few PSI either way on either the PRV, the gauge or both - but 90 PSI sounds like a problem
was there any extra shims in there or anything else that might have changed the pressure setting ?
[Edited on 15/4/2021 by mcerd1]
bumpy - 15/4/21 at 01:43 PM
Nope neither pump had been tampered with. Namely an old one that spontaneously doubled its reading after a winter storage in a garage, and a brand now one from Burtons.
[Edited on 15/4/21 by bumpy]
steve m - 15/4/21 at 04:15 PM
So lets have a recap on what i believe has gone on here
Car and Engine last year ran perfectly, good normal oil pressure conducive with a Pinto engine
NOTHING HAS BEEN DONE TO THE ENGINE since last year ? and i really do mean NOTHING
Yet this year on first start up, the oil pressure has jumped to 90psi and remains there ?
and even with a NEW pump, the pressure is still 90 psi ?
From this we can discount the oil pumps, if two have been used, and verified by a couple of different guages,
and you say you replaced the two filters, why has your engine got two ?as ive never come across that,
The spin off filters have a valve in them, and i wonder if the one you have fitted is faulty (not sure how) but apart from OIL, and TWO ? Filters that is the only work on the engine from last year, so i believe
My last point is, that running 90psi on the oil system is going to play havoc with the crankshaft end seals, but at least on a Pinto the spray bar and valve train should be good !!
bumpy - 15/4/21 at 04:22 PM
We seem to have got caught in a cyclic discussion where blame has been put on the PRV, so I would like to explore this problem from a different angle if possible.
On the Pinto engine the Ford Motor Company and Autodata books specify an oil pressure of 37psi at 2000rpm with hot oil. This is a stated fact.
Now under just those conditions, my engine pressure, using a variety of matched senders and gauges, reads 75-80psi.
At the normal 37psi the PRV is not called into play at all, as its lower working limit of 58psi has not been reached. So even if it was welded shut it would have no impact at all on that reading and cant be responsible for the 75-80psi
So I think we need to consider alternative possibilities for the high readings.
bumpy - 15/4/21 at 04:28 PM
Sorry, I may not have made it clear, but the the engine only has the one standard oil filter. This was changed twice - hence the 'two'
"From this we can discount the oil pumps, if two have been used" This is the conclusion I draw in my last post and with it we can discount the PRV.
mcerd1 - 15/4/21 at 06:13 PM
^ as unlikley as it might be its not impossible that you could have 2 doggy pumps (or gauges for that matter)
maybe you could borrow another known working pump/gauge rule things out completely - where abouts in the world are you ?
jacko - 15/4/21 at 06:34 PM
Hi
If it’s not the pump s or gauges or oil filters what could it be only a blocked pipe / gallery you have said the cam pipe is ok but is it clear and not blocked where it pushes into the block can you see oil coming up to the top and spraying oil on the tappers
I think we are grasping at straws on this one
Graham
Oddified - 15/4/21 at 07:58 PM
Is the oil filter fitted on the engine block as standard or are you using a remote filter/take off?. Is the oil pressure gauge fitted into the engine block / T piece on the oil pressure switch?.
Mr Whippy - 15/4/21 at 09:56 PM
This is why fitting an oil pressure warning light is better than a gauge. It prevents over analysing everything. The light goes out, it runs, f£ck it...just drive the car.
mcerd1 - 16/4/21 at 06:19 PM
Think about it like this -
The oil pressure is meant to be ~45-65 PSI depending on the PRV in the pump (ignoring the 75-80 PSI HP ones burtons offer)
Some things like cold oil, blocked filters/galleries, wrong oil - could all have an effect of raising the pressure - but none of them can take it past what the pressure relief valve will allow (at least not by much or for long)
If the pressure builds through the system for any reason the PRV should open limiting it
Even if you could somehow have a pocket of high pressure oil somewhere on the engine (stuck behind some kind of one way valve) it can't ever be higher than the PRV will allow - oil isn't going to flow from a low pressure area into a high pressure area
all this really only leaves 2 options - either the PRV isn't working correctly for some reason (set too high, stuck or the outlet blocked / partially blocked)
or the gauges are reading incorrectly
short of you having a second secret oil pump somewhere in the engine - there really isn't anywhere else this can be coming from...
[Edited on 16/4/2021 by mcerd1]
Mr Whippy - 16/4/21 at 06:51 PM
Exactly
rusty nuts - 16/4/21 at 08:18 PM
Exactly what I said in my first post but maybe not so well described
cliftyhanger - 17/4/21 at 07:12 AM
Absolutely. Lots of people like extra gauges, but they are called "worry gauges" for a reason. Fuel gauge, essential. And I do like a temp gauge. On my current runabout (Honda Jazz, which reminds me that I need to buy some beige clothing) it has a natty temp indicator that just changes colour, very simple and ideal for a tintop. But my old cars, temp gauge is handy....
I have had oil pressure, oil temp, even years ago a vacuum gauge. But all gone, as they become a distraction. The only thing left in my car is the AFR gauge, and at some point I would like to replace that with something less distracting.
I have considered a 20psi oil pressure warning light. te normal ones are about 7psi I think, by which time it is all over. 20 would give a better chance of avoiding total carnage.
jps - 17/4/21 at 07:23 AM
Have you changed the oil pressure sender (not the gauge)? It’s not explicitly stated in your OP although in a later reply on the thread where someone has mentioned gauge and sender you said it’s been done.
As others have posted, it seems there are limited potential culprits for the high reading (and they’ve all been listed) and, inevitably, it must be one of them that’s causing it.
snapper - 18/4/21 at 06:28 AM
I’ve read all the posts and don’t want to go over all that’s been said before but just add my thinking.
Oil pressure is created by resistance to flow but there are many places oil squeezes out of bearings and oil feeds but mostly the main bearings crest the main resistance to oil flow hence why it is an indicator of bearing health.
If it’s a 1 wire sensor it will earth through the block make sure there is a few clean threads to connect the electrical path to the block. PTFE tape is sometimes used and can insulate the gauge signal. A good earth is needed under the dash where all gauges should be earthed at one point.
A good engine block earth is needed as sensor measure resistance, a broken gauge wire throws the gauge to max end of the scale so maybe it’s a resistance issue.
I would consider running a temporary earth to the battery from the sender and all new wires to the gauge from the sender, maybe pop the gauge out of the dash and wire it direct to sender and battery.
Oil pressure senders have a perforated plug that lets oil through to the pressure sensor if this is full of crud MAYBE it’s not letting oil pressure out just building pressure. Check sender unit perhaps swap with someone else to try in their engine.
I have no other ideas on this but please please let us know if you solve the problem.
jacko - 18/4/21 at 03:43 PM
Snapper he has used a capillary gauge i presume he means one with a pipe
G
[Edited on 18/4/21 by jacko]
Toys2 - 19/4/21 at 08:08 AM
Is it possible to pressurise the oil if a piston ring is passing?
Although isn't the crankcase breather meant to deal with this? What if that was blocked?
[Edited on 19/4/21 by Toys2]
Mr Whippy - 19/4/21 at 11:05 AM
No it's in a totally different league. By passing pistons is like less than 5psi, you can just put your palm over the oil filler to block it off. If you had 80psi inside the engine void it would be very entertaining and explosively oily if not quite literally explode
[Edited on 19/4/21 by Mr Whippy]
jacko - 25/4/21 at 09:50 AM
Bump any news on the problem
Graham
jacko - 4/5/21 at 06:25 PM
Any news on what caused the high pressure ?
It’s always interesting to know for future reference
Graham
steve m - 4/5/21 at 08:20 PM
Seems the pressure is to high on Bumpy
