Hi folks,
A bit of advice please. As the car is unfinished and I only start it occasionally, my carbs became so gummed up that last time I came to start it
there was fuel peeing out of all four trumpets onto the workshop floor.
So I've stripped one down and cleaned it up. However, I noticed one hole on one side is still bunged up and I cannot work out if it goes
anywhere. The equivalent on the other side seems clear and I assume the blocked one has had fuel in it to become blocked? I can't easily clean it
out though.
See the holes in the pics marked with a scriber. The gasket has holes too but there is a closed off casing sitting above each hole as if there's
an option in the casting. Don't know if these holes act as a reservoir for one of the jets or are there for options in the casting?
Also, I had the carb in the ultrasonic tank a couple of times. Will this have taken the grease out of the butterfly spindle bearings. I believe
they're sealed but don't know how well?
Pics in archive under Weber.
Ian
