4 AGE fuel pump
blockhead_rich - 2/2/05 at 10:48 PM
Oi Oi
Can anyone recommend a make and part No. for a fuel pump? Has anyone used a Bosch one with good results? Also where is the best place to fix it - near the tank or in the engine bay?
Cheers for your help!
Rich
paulbeyer - 3/2/05 at 12:03 AM
Hi Rich,
I got a Bosch fuel pump off a 3 series BMW from a scrappy and mounted it near the tank. The good thing about this pump was the rubber cover it was housed in. When I removed the pump it was as good as new.
zetec - 3/2/05 at 08:04 AM
if you are running a single pump injection system then near the tank and below it's lowest point. The other options for the pump are out of tank pumps from a Vauxhall, easy to fit as they have standard push fit connections.
Rob Lane - 3/2/05 at 09:53 AM
I used a Vaux too, it's from a Cavalier.
They cope OK and are easy push fit tube connecter.
They don't like bits in them though !
I went through 3 pumps in succession when pre filter could not cope with fine swarf in tank (don't ask). Fortunately scrappy only charged me £3 each.
I now have a pre-filter and an injection post filter. The post filter is the Cav one bought new.
blockhead_rich - 23/2/05 at 08:04 PM
OK, took all your advice and got myself the Calerier Fuel pump and filter, etc. Looks quite good now it's shot blasted and the brackets are all powerd coated.
So, do I need to fit the regulator that comes with the assembly from the Vauxhall and do I need to mount it the same way as vauxhall did, i.e. with rubber mounts onto the chassis.
Rich
