Hi all,
I'm trying to find out the measurements/dimensions on two different flywheels so I can do a solid mass conversion on my project. There is a off
the shelf item that is a direct fit but it will run me between £1600-2100 depending on spec.
There is another vehicle that shares the same block/crank as my car that has a solid mass kit available for less than £600 shipped. As you can emagine
this would be far preferable to the expensive one.
The problem is buying a standard DMf and the possible SMF donor just to check side by side is going to be very costly for a maybe. So does anyone know
of a resource that will have dimensions, tooth number etc ect maybe a parts book or something? The part numbers are not exactly much help either due
to the different vehicle platforms.
I have approached mercedes twice now and both times I've been met with blank faces by sales desk people who likely don't know what a
flywheel is so thats a dead end.
Any thoughts appreciated
Jay
[Edited on 8/3/23 by J666AYP]
does this help... https://www.hammerkupplungen.com/uploads/TECHNICAL%20CATALOGUE1561536520.pdf
Why are you looking at a solid flywheel, at that cost to replace the dual mass one is it really worth the money?
I've had a dual mass go before but some say replacing it with a solid one will wear out the gearbox quicker by not damping loads or vibration
from the engine to the gearbox.
I've had a dual mass go before but some say replacing it with a solid one will wear out the gearbox quicker by not damping loads or vibration from the engine to the gearbox.
