I have a Polo radiator where both pipe connections and the thermostat are all on the same side. I'm finding it surprisingly hard to put the
radiator in place without having to put a tight 90 degrees on one or both pipes. I can move it sideways slightly to get it to work, but not having the
radiator central would make me twitch every time I looked at it (The Healey bodywork means the radiator is a lot more visible than an average seven).
It all works perfectly fine if I put it vertically with all the connections at the top. It physically fits, I can mount it central and it doesn't
foul any other components. Is there any cooling issue with using a radiator vertically?
Can't help with radiator (coolant in/out) orientation affecting it's performance - no experience of fitting one in that way.
I used a Polo radiator on the Pinto engined MK Indy I built. On the lower pipe I had to have a 90° bend right out of the radiator. Worked fine. The
nose of the MK wouldn't have allowed fitting the radiator anything but the normal orientation.
Thinking aloud - if the coolant in/out pipes were both at the top of the radiator, I'd be surprised if the coolant flowed very well through the
radiator. Might end up with very poor cooling and therefore overheating.
The original Healey radiator would have had pipes and tanks at top and bottom, the polo radiator has a divider in the end tank between the
inlet/outlet so in your orientation the flow has to pass down one side and back up the other, effectively operating as one double length but half
width radiator.
Just check there is a divider present between the inlet/outlet, I have had cheap copy radiators that have this part missing which made them useless as
the coolant flow takes the easiest route.
Dave
Originally posted by obfripper
The original Healey radiator would have had pipes and tanks at top and bottom, the polo radiator has a divider in the end tank between the inlet/outlet so in your orientation the flow has to pass down one side and back up the other, effectively operating as one double length but half width radiator.
Just check there is a divider present between the inlet/outlet, I have had cheap copy radiators that have this part missing which made them useless as the coolant flow takes the easiest route.
Dave
Originally posted by nick205
I used a Polo radiator on the Pinto engined MK Indy I built. On the lower pipe I had to have a 90° bend right out of the radiator. Worked fine. The nose of the MK wouldn't have allowed fitting the radiator anything but the normal orientation.
From memory, I got my 90° bend, by cutting from another coolant hose. Then a length of Ally pipe, then one of those flexi-hoses to reach the Pinto.
I managed to get the bonnet out of the shed yesterday, and I've put things in their rough position;
It seems to fit well vertically, although the bonnet and rad both need a bit of adjustment as they're just resting on a plank of wood for
now!!
This is the inspiration I have for the front end, a vertical rad in the middle with metalwork either side;
I don't know how close I can get but I can see what happens.
[Edited on 12-10-23 by Slimy38]
