I need to precisely align these. The diff is mounted directly to the engine so the is no driveshaft or UJ.
When I finger tighten the bolts there is about 1/2mm of play. I can get it nicely aligned on the bench with a dial indicator, but it's not going
to be easy when on the car.
I was thinking about drilling some 8mm holes and fitting some locating pegs. Glis this a good/bad idea? Other suggestions?
[Edited on 4/8/25 by nick9one1]
Clocking the flanges on the outside diameter does rely on the outer being concentric with the center line, so you need to check that. I'd guess
once you've clocked the flanges, drilling and fitting alignment dowels should ensure the fit.
The other issue you then have is perfect alignment of engine and diff. Even the slightest misalignment will put load on yhe input/output shaft
bearings and cause premature failure.
I'd think using a rubber doughnut type coupling would be a better solution.
Originally posted by adithorp
Clocking the flanges on the outside diameter does rely on the outer being concentric with the center line, so you need to check that. I'd guess once you've clocked the flanges, drilling and fitting alignment dowels should ensure the fit.
The other issue you then have is perfect alignment of engine and diff. Even the slightest misalignment will put load on yhe input/output shaft bearings and cause premature failure.
Anyone got a sprocket adaptor for a kawasaki zx1200 or zx1400
Can you set them up in a lathe and machine a short spigot on one half and a recess for it to fit into in the other?
I'd be making the engine and diff a single assembly that bolts out/in, nothing else is going to be reliable there.
What is the rear axle, diff and drive shafts from?
Are they all from the same donor car?
Looks like there is part of a VW beetle with toque. Suspension
You probably cant tell from the first picture I posted, but I've done this. I built a subframe that both rigidly mount to. The subframe then sits on rubber engine mounts.
(upside down)
[Edited on 6/8/25 by nick9one1]
