Hello All, I am about to install my exhausts and I am worried about getting the silencers too close to the side panels. Is there a rule of thumb for the distance between the silencer / manifold and GRP? I could do with it being as close as possible to make the manifold ergonomics work, otherwise I'd just move it out a bit. I don't have any guidance in my build manual and I haven't been able to find anything definitive on-line anywhere. All thoughts welcome.
Headers, exhaust or silencer? Silencer doesn't need much gap. Seen plenty at an inch or less (particularly at the back). Headers and pipe want a bit more as they're always hotter. A couple of inches I'd guess.
Thank you, that ties in with what I had hoped.
Bit of everything really, I need to fix the silencer distance first, but the gap here is amplified where the side pipe meets the manifold. I
don't want this too far from the side panel, but I don't want the silencer too close.
Exhaust bandage is your friend on the headers it helps keep the heat down and stops you burning your self on them
If you look in my photos archives you may give you some ideas
Graham[pg]90317[/
[Edited on 10/11/25 by jacko]
Installed my MK Indy exhaust like this, with no issues
Thanks Both, I plan to use heat wrap under the bonnet to keep the engine bay temps down, but I was worried about the proximity on the out side. Both of yours are closer than I had expected with no issues, so that gives me some confidence! I will have a look at your albums. Thanks!
Good to know.
In my head the manifold would be glowing at 700 degrees, the silencer is hot enough to melt your leg and there are flames out the end trying to cook
the tyre. While I suspected this was OTT I wasn't sure where reality was, your car sounds cold in comparison!
One thing to add to what others have said - pay some attention to the outlet from the silencer. On mine the outlet had a short 45 degree angled bend about 80mm from the GRP rear wheel arch. The builder (not me) had assumed the 45 degree bend would be sufficient to direct the hot gasses away but it had burnt a hole through the arch. I changed it to a full 90 swept bend that came out to very slightly beyond the wheelarch. I covered the hole with a bit of thin stainless to both deal with the ugly hole and act as a heat deflector and its been fine since. I did manage to burn a hole in the wheel arch of my trailer running the engine with the car on the trailer though! The gasses exiting the exhaust are hotter than you might think and there are the odd flashes of flame on the overrun on track days.
The only thing that bothered me was if a Yong child put there hand on the exhaust when hot
Graham
only thing that bothered me was if a Young child put there hand on the exhaust when hot
This may help you
[Edited on 11/11/25 by jacko]
This has been a worry for me too. The manifold, in particular, would leave a horrible burn![]()
I've seen Silencer shields (to protect people getting in/out I guess??).
Has anyone ever seen a heat shield on the manifold?
Originally posted by jacko
This may help you
Complete exhaust for a better view.
MK supplied.
The end bend was ample to deflect heat and fumes away from the GRP wheel arch.
Makes me laugh that the IVA doesn't require heat shields. Small kid falling on that has life changing injuries through no fault of their own. I personally couldn't use that in public without adding shielding, for my own peace of mind. Looks lovely though.
