fuel hose for water?
scutter - 17/2/05 at 09:04 PM
As it say's above can 8mm fuel hose be used as water hose, as i need to plumb in my Dolomite header tank in?
Thinking of doing it as below.
ATB Dan.
[img][/img]
indykid - 17/2/05 at 09:43 PM
i have and have had no problems.
afaik, water will be held in any rubber hose, fuel needs to be special hose as it eats some rubbers, brake fluid can get through the gaps in normal hose so again needs its special hose
that's my understanding anyway
routing looks reasonable as long as the tank will actually feed the system, ie water level above thermostat housing
hth
tom
Hellfire - 18/2/05 at 12:57 AM
Most of the time - water can run through petrol pipes but not vica versa
scutter - 18/2/05 at 08:05 AM
Excellent, time to go shopping.
Many thanks Dan.
Danozeman - 18/2/05 at 09:11 PM
Ive been running this on my calibra for ages as i couldnt get 8mm coolant hose and needed it quick. NO probs
fester - 24/2/05 at 08:54 PM
If in doubt,contact your local hydraulics company(there is a Pirtek almost everywhere now) and ask them for 3/8" P.O.A. This stands for petroleums,oils and air. This stuff is very flexible, cheap and has a good burst pressure(which is the important bit!). It also looks good!
Good luck!
fester - 24/2/05 at 08:59 PM
CORRECTION! Don't ask for 3/8",ask for 1/4" which is equivalent to 6mm.......DOH!
scutter - 24/2/05 at 09:51 PM
Cheers fester, got fuel hose from premier wiring 5/16 is 8mm which is what i need and rated upto 150psi
ATB Dan.
