I have a fuel problem and here is my threory. Could it be possible to run a cooling system pipe from the header tank to close to the filter king. This
would then vaperize's the fuel in the filter king which increases the pressure,cutting off the supply to the carbs. And that is why the engine
cuts out after about one or two miles when warm.
Carl
PS Have you any other Ideas
[Edited on 5/5/05 by carlgeldard]
Carl,
Have you tried just turning the pressure up a bit? You might be using all the fuel in the carbs up?
Just a thought.
I am going to do that tonight. I am on 3.5psi at the moment but the gauge is not force to be right and I will get a second hand filter king if needed
from that good supplier in Dewsbury. After I have move that cooling pipe.
Carl
I'd have thought fuel would have to be very hot to vapourise
Wouldn't expect a water pipe to do it. But could be wrong.
