Help!
I need some engine mounts that are 15MM thick........ any suggestions? The current ones are 40mm and put the engine 1" too high in the chassis.
Can you not modify/redesign the rest of the engine mounts.
Landrover mounts are slightly thinner @ approx 36mm.
Escort mounts (mk 2 at least) have rubbers about 1" thick, but would need one side bounding to existing engine mount
For some reason i've got a real issue with making engine mounts. Don't know why but i'm desparate not to make them!
Silly i know .......... but there we are.
Try these guys
http://www.gmt.gb.com/
something i talked about with james the other day..
if you're not keen to remake the engine mounts, another option is to cut out the plate on the chassis (assuming its on top of the 1" bottom
engine bay rails) and re-weld it on the underside, hence making the engine/mount 1" lower..
Ned.
I'll knock some up if you need them Mike
Just looked at the link mentioned ealier in this thread. Bloody useful range of mountings listed. I've just ordered one to adjust the postion of my engine.
Glad you liked the link....
Thinking about it, I still have a pile of your engine mounts in my garage, remind me to give those back to you when you come over!
great more mounts ......... thats 2 lots of escort, 2 lots of westfield and 1 leugo .....
see why i've got a thing about making my own ?????
