Hi all
Just got a ally sump off ebay, no baffle plate
Anyone got one ? If so could you post a pic and dimentions so i can try and get one made?
Adrian
I've got one, but it's bolted to my engine and the engine is in the car.
I'm not taking it out even for you
The baffle is a flat plate with a strainer size hole in the middle. Thre is a tube (the same size as the hole) which goes down to nearly the base of
the sump.
You need the pick up pipe which goes with the RS2000 sump, which is different to the normal pinto one.
Mark
Thanks Mark
Got the correct pick up, just no baffle
Adrian
