MT75 three prong flange. What thread?
garage19 - 17/6/05 at 08:10 PM
Just bolting my prop up.
I have new Ford bolts for the diff end but as i have removed the rubber damper from the MT75 i need to get my own bolts.
I have tried some M12 bolts but they are not the correct thread pitch
Does any one know what the thread pitch is?
As the bolts will be under a shearing force, should i use 8.8 or 12.9 tensile bolts?
Doug.
The Stoat - 18/6/05 at 11:02 AM
I have some used ones (off of a type 9 if they are the same) if you would like.
The Stoat.
Mix - 18/6/05 at 02:41 PM
If you still have the 'studs' that held the 'do'nut' on then why not cut off the surplus thread and use them?
Mick
tks - 18/6/05 at 02:50 PM
8.8 should do the trick..
diff bolts are M10, 1mm pitch (metric)
sow i guess it an easy task..
Tks
garage19 - 18/6/05 at 10:14 PM
Nope, unfortunatly i filed them at an early stage of the build!
Mick
garage19 - 18/6/05 at 10:16 PM
Tks
As i said already got new diff bolts, its the gearbox end im stumped
Mix - 19/6/05 at 08:28 AM
OK I've just dug one of the original studs out. The thread is 12mm 1.75 pitch.
If that's the size you tried before I suggest you look at cleaning the threads as Ford had used their blue thread locking compound on mine and it could be that making the thread stiff.
Mick
garage19 - 19/6/05 at 03:16 PM
Many thanks Mick.
Is 1.75mm standard M12 pitch or coarser?
Will go and check the pitch on the bolts I have.
Thanks,
Doug.
Mix - 19/6/05 at 03:29 PM
As far as I'm aware that's the standard pitch. Good luck
Mick
