Why doesn't anyone use these?
I didn't because my Indy had brackets already in for the rear one
You'd also need custom made driveshafts.
liam
You would also have to turn it upside down to get it to run the right way, leading to breather and lubrication difficulties.
It runs the same way as a rear diff actually
Liam
Are the ratios the same?? Not got the manual in front of me but isn't there a chain drive with a reduction to the front prop shaft ?
Mick
Quite right too, I stand corrected. You're still driving it the wrong way though, and it wont be the easiest thing to fit due to the already
mentioned driveshaft problems. How is the nearside transfer drive shaft located anyway? Looks to be a lot of work when you can use a rear diff so much
easier.
[Edited on 1/7/05 by gazza285]
One of the drive shafts goes through the sump on the 2.0l XR4x4 that Ben Copeland stripped.
HTH Mike
Originally posted by gazza285You're still driving it the wrong way though,
Yep, you'd need to mount the sump as well
hold on a minute! if the diff is going the wrong way, and the engine too, and the gearbox, you'd still be moving forward with the diff running
backwards! and if it was a backward spin engine, with a normal box, you'd have 5 reverse gears, but with the diff at least happy thinking all is
well!
