Hi all
I'm planning on making an airbox and ducting air to it from infront of the radiator, i've been offered some 2.5" hose to use for the
ducting, will this be big enough for a 2.0 pinto with twin 45's?
Adrian
It sounds big enough. Should be ok with a funnel at the start etc. Will it get you some more power? Any sketches to show what you are thinking of?
I would have thought that 2.5 in dia pipe would be restrictive when used with twin 45s, also the longer the pipe the more restictive it's likely to be. Just my opinion though. If the car is up and running try fitting the pipe temporarily and road testing to see results?
Hi Guys
Hose only needs to be about 2' long, it will have a cone filter at the front
Not really trying to gain power, but the car does feel sluggish when hot
I'm hoping to get the air box vac formed, and will fit over the trumpets like a panel filter
Adrian
Adrian,
I have been thinking of doing exactly the same. Any chance of getting more than one made?
Not really sure its big enough and here's my line of thinking why not (roughly)
Area of 2.5 inch pipe is 4.9inch sqaure
Area of 4 weber venturis say 1 1/4 dia is also 4.9 inch square.
So its pretty evenly balanced not taking into account any possible ram air effect of forward motion.
I would look for a 4 inch reinforced tubing from the likes of an eberspacher space heater if I was you.
Your idea is sound though as cold air will give you more power than hot air ( something to do with density )
[Edited on 11/7/05 by omega 24 v6]
Hi Graham
I'm hoping to get one made as a favour, but if it works i should be able to get more done cheaply
Omega 24 v6
I did think about the area of the webers, but they dont all suck together, i've also looked at my tin top, a 1.8 vectra, the hose from the air
filter is about 2.25" ID.
The max hose i can fit into the air filter is 3.5", so that may be the best bet ?
good point stu16v never thought of it that way.
Thats why this group is so good everyone's got their own ideas about things
