Hi everyone,
I spotted out very nice V6 2.3 Cologne (carburettor) for reasonable price - 63 EUR (not bought yet).
Trouble is, gearbox end is broken, so I'll need new gearbox.
What gearbox will fit nicely on this engine?
and will any Sierra diff will be fine or have to I find something special?
Right now seems to me that there is Type 9 gearbox fitted, but that can not be right as far as i know. What do you think?
Waht is overall opinion about this engine?
[Edited on 26-7-05 by macintosh]
It will be a heavy duty type 9 gearbox, I guess it was in a Taunus??? (don't really know the european models very well!)
Sierra diff will be fine. This engine was used (in the UK at least) in the sierra 2.3 ghia.
Other sources for the same gearbox are (in "UK models"!) mk 2 granada v6 models, early mk3 granada v6 models, sierra 2.3 ghia (though most
were auto), capri 2.8i (late ones) and sierra XR4i (plus the Merkur XR4ti)
The engine is very heavy for the power that it generates, but it is nice and revvy, and probably worth 63 euros for the inlet manifold and
carburettor. These will then bolt straight onto the 2.8 litre cologne engine, which is much better and exactly the same dimensionally.
If you build your car around the 2.3 engine, and look out for a 2.8, then put the carb and manifold from the 2.3 onto that you should be fine.
They are both very heavy engines, that is the downside!
[Edited on 26/7/05 by NS Dev]
Other sources for the same gearbox are (in "UK models"!) mk 2 granada v6 models, early mk3 granada v6 models, sierra 2.3 ghia (though most were auto), capri 2.8i (late ones) and sierra XR4i (plus the Merkur XR4ti)
right, the car that the engine came from will be a Sierra 2.3 ghia, most were automatic transmission but this must be from a rare manual one.
I don't know the weight but I would guess, having moved both on my engine crane, that the v6 is 50% heavier than the Pinto 4 cyl.
If you have the option, the pinto is probably better as it is easier to get parts for, especially in your part of the world I would think.
I don't know the car market in Estonia but are BMW 4 cylinder cars more common? There is no reason not to use a BMW 318 engine or similar from
the earlier models, if parts are easier to get for you (I guess Fords didn't sell as well as the german makes)
Estonian 7 manufacturer:
http://www.racetech.ee/
HTH,
James
mmmmmm, interesting. Was going to suggest that BMW 4 cylinder engine and 5 speed box from a 318, coupled to a Lada live axle would probably be an
effective solution in Estonia, but didn't really know the availabilty of 318's, but I guessed that they were a lot more common than most
Fords.
It seems that Estfield have used this drivetrain a fair bit.
mmmmmm, interesting. Was going to suggest that BMW 4 cylinder engine and 5 speed box from a 318, coupled to a Lada live axle would probably be an effective solution in Estonia, but didn't really know the availabilty of 318's, but I guessed that they were a lot more common than most Fords.
