Ok need an answer to this if I get a zetec what will I have to change on the engine to get it to fit my type 9.
Clutch? FlyWheel?
Currently I have a 1.6 CHV installed and am thinking about Zetec
Hi,
If you are using a standard CVH flywheel at the moment, then the standard 1.6/1.8 fiesta /Escort zetec flywheel should be ok.
Normal things to make it mount are:
flywheel (only if fitting a 2.0)
clutch
spigot bearing
You'll also need to trim down the middle of your current engine - gearbox spacer plate
Don't forget to lower the zetec sump, too
Use your CVH starter.
S
[Edited on 29/7/05 by stevebubs]
What do you mean "Lower the Zetec Sump"?
The later zetec has a cast sump which has to be trimmed to allow the starter to fit the type 9. The earlier zetec does not need this to be done as there is enough room for the starter to miss the sump.
You nee to change one engine mount -- I can't remember which
Upgrading again! Ps your pictures are in my archive.
That would be raising it then
