Type 9 bearings again
Danozeman - 4/8/05 at 05:40 PM
Does any on know how easy it is to change the input shaft bearing?
MIne need doing and i cant be bothered if it an arse. I'll get another box.
johnjulie - 4/8/05 at 07:02 PM
Just wondered if you are changing the bearings because of the play in the shaft.
THis is normal.
Cheers John
[Edited on 4/8/05 by johnjulie]
fellowes - 5/8/05 at 01:02 AM
How much play is normal? Is there a max amount?
Danozeman - 5/8/05 at 04:05 PM
I was yes. I did wonder as the bearing is not rough or anything just the play. Is it ok if left then? I assume the spigot will stop it slapping about anyway?
johnjulie - 5/8/05 at 07:19 PM
Not sure on how much play is OK, but there is a fair bit off side to side movement if you wiggle the end of the shaft!
Cheers J&J
Danozeman - 7/8/05 at 11:00 AM
Thats what ive got. A bit of wobble if i waggle the tip. (oooh errr missus).
Im not not gonna do it just yet. Got too much else on and want to get my ar looking like a car.
MikeRJ - 7/8/05 at 11:34 AM
There will always be some movement as the shaft is only supported by a single ball race when not bolted to an engine. The spigot bearing in the end of the crank exists for exactly this reason.
Danozeman - 7/8/05 at 05:05 PM
Nice one. 20 quid saved then. Ill leave it and see how it goes.
Cheers chaps.
