Gotta 1600 xflow coupled up to a Capri 4-speed box. Used the Capri clutch assy, the release bearing being shorter. But no free movement at the clutch
lever. What did I do wrong?
This also refers :-
http://www.locostbuilders.co.uk/viewthread.php?tid=25450
Helpful suggestions VERY welcome!
P.S. Didn't someone have details of g/box-clutch-bearing on their site? Any info?
[Edited on 6/8/05 by Dick Axtell]
Haven't you thought about a Sierra type 9 box?
Cheers John
Do you mean the clutch is not disengaging, have you put the friction plate the right way round?
Hint: one side has "flywheel" stamped on it!
