Well i've only done 40 test miles around camp, haven't even past SVA and i'm thinking of an engine change, looking for more
reliability.
So Zetec's come into the frame(why not everyone else is).
The question is, Is there a differance in height between 1.8's and 2.0's?
Many thanks Dan.
any use?
I've got that pic thanks Dave, may have to go scappies with my tape measure.
Would like to go 2.0L as size matters
ATB Dan.
I'll get the tape measure out on the 1800 i have.
the 2 litre looks like this with a chopped sump and MT75 box attatched,thank zetec for the pic
I'll get the tape measure out on my 2 litre........
From very bottom of std sump to top of cams 615 mm (ish)
From sump gasket where it meets the block to top of cams 400mm (ish)
Hope this helps
Cheers fellas, looks like they are the same size, from Daves picture the 1800 height is 666mm (must be a ford joke).
Time to start looking for a 2L lump.
Atb Dan.
Get it through sva first Dan then throw the 1700 my way !!
Jason
I'll bear that in mind Jason, as i need to fund the purchase of some 45's
ATB Dan.
I could px three sets of 40's !!
Jason
