I am trying to fit what I believe is a Tiger stainless exhaust system to my Locost which has a 1700 xflow. The problem I am having is the clearance
between manifold pipes and the diagonal brace.
1) has anyone fitted this exhaust system, if so how?
2) what clearance would I need between the manifold pipes and diagonal brace to allow for engine movement when running?
3) could I remove the brace and replace it with verticle ones?
Many thanks for any help, regards,
You may be able to remove the diagonal and replace with an offset 'v' arrangment , or an offset'v' upside down, I think someone
has braced it that way...
