Sorry to bring this subject up yet again but still got a few questions:
- Should the carbs be mounted verticaly on the manifold or should they be at a slight angle so that the bowls underneath are horizontal?
- Does the vaccuum hose need to connect on to the manifold, and if so do you need to connect them onto each stub to stop the pulsating effect
you'd probably get?? Am getting really confused by seeing pictures of bogg bros carbs that have no pipes connected to them look delightfully
simple! Wish I could afford to buy one but affraid its just not on the cards! Cheers for any help you can give.....Oli.
The vent pipes on the carbs dont need connecting to anything. Just leave them to the atmosphere.
When I asked Stephen at b-bros thats what I was told.I said ididnt fancy that as I was a bit fussy. He said they could be connected to a little
breather filter.Havnt got round to it yet tho.There is also 2 more conections for carb heaters.
The carbs need to be at an angle so that the floats are levell or they wont hold enough fuel.Differant carbs have differant angles.
I havnt forgoten and I will dig some more photos out.
ps look in my archive under bog brothers.
regards warren
[Edited on 16/11/05 by big_wasa]
Hi Oliwb i am just making a inlet manifold for my pinto to zx9r carbs let me now how you get on with yours when there made .
plus thanks to BIG-WASA for the help in the photos
keep them coming there spot on
Jacko
Oh yeh
regards photos
Will send that pot out tommorow Oli.
ok cool, thanks guys.....when you say the vent pipes do you mean the ones connected to the diaphram on top of the carbs? (bit dense!) We're just at the stage where we're trying to draw up a CAD model of the manifold. Gonna make a nice one and maybe knock up a few and ebay them as long as mine works properly. At the moment trying to work out a reasonable way of machining them or casting them and then machinging them nicely so that we can avoid the sort of welded on pipe effect that even the very expensive ones have.....having a bit of a nightmare at the moment with all the different angles etc! Gotta curve this way then that way and then another before it'll finaly fit...and oh yeh gotta get thinnner aswell! Anyway thanks guys any pics would be much appreciated...couldn't seem to access the bog bro's archive for some reason?? Thanks again...will let you know how I get on....Oli.
Originally posted by big_wasa
Oh yehregards photos
pot?????
what's going on here then!!???![]()
Olli, yep I mean diaphragm vents.
Olli give me your email and ill send some pics.
It you look in my archive under my avatar when I post you will find loads. If you look under my user name under photo archive then it’s empty? Site
doesn’t like the under score in my user name big_wasa. Again in my archive look under bog bros as the site doesn’t like apostrophise and comas ect.
Regards warren
Still can't open anything to do with bogg bros apart from your files with the article in....get an SQL error whatever that means??! Could be
that I'm using a mac....which are clearly too good for the old PC based systems...
Yeh I cant remove the errors either
Oli
top right link to Bog Bros works for my Mac, SQL errors on all others in Safari
Caber
[Edited on 11/17/2005 by caber]
Thanks...finaly got some pics via the link sent in e-mails.....not sure why it's not working properly, bit annoying though.....Oli.
Ok, had a conversation with bogg bro's today and learnt alot actually...thoroughly helpful guy and very supportive. Managed to answer a few
questions I had about leaving things to the atmosphere although I think I might have confused him alittle when I started talking about variances in
manifold pressure etc etc. However we are still confused about one aspect which no one has answered yet and thats what pipe C+D do?? We believe pipe
A is the fuel pipe, B is the vaccum pipe for the top diaphrams which apparently is OK being left to the atmosphere?? Does anyone know what these
pipes would have been attached to and what they did on the bike (bike in question is a 99' Kawasaki Ninja ZX7r (we think) If anyone's got
any pictures of one in situ that would be amazing!.....Cheers for any help...Oli.
