As the V6 Duratec has got a reputation for breaking water pumps I decided to cut it out altogether and fit a
Davies, Craig EWP® Electric Water Pump
Apparently it will even give me a sizeable power boost too
and I now wonder which layout would be best for my middy.
Option 1: Instal the pump close to the front mounted radiator
Option 2: Install the pump in the engine bay
I've also got to tee the cabin heater (yeah I'm a wuss) pipes in somewhere. Ideally these would come off the rad on an electric valve. The
original takeoff was straight from a water jacket around the oil filter but I have had to remove this to incorporate the EWP.
Your comments would be appreciated
How much do those things cost?
I bought the pump and 'intelligent' controller for £240 in post. A bit pricey but the standard water pump is also not cheap. According to their blurb I should see an extra 20 horses too ....... which is nice.
Originally posted by smart51
An electric pump will probably run at 1 speed. This means that it will use less power at high engine speed leaving you with more at the flywheel. You can bet that the worst engine they've seen saves 20 BHP and so that's the one they quote.
That said, even if it save 5 BHP, are you going to say no?
Mechanical pumps run at the speed of the engine. They have got to be up to the job of cooling the engine and idle and so often run furiously fast at high RPM.
The controller matches the pump speed to the engine temperature - very slow during warm-up getting progressively faster at full working temperature.
Originally posted by 02GF74
Does the pump have a facility to run on after the engine has stopped to allow even cooling down after a hard blast?
That is another benefit of non engine driven pumps.
I would do a lot of research into the "Craig David's" before fitting one in order to make things more reliable!! They are used a fair
bit on bike engines when people fit dry sumps because they use the mechanical pump drive to drive the dry sump pumps, and they have a reputation for
being fairly cheaply made (although not to buy) and failing quite often - I have heard of them failing within a few hundred track miles so I certainly
cant see it being more reliable than an OEM Ford part even if they do have a reputation for unreliability (relative to other cars which have water
pumps that last 150k miles maybe).
Also, I really wouldnt believe the power gains claimed, if a water pump really took 20bhp to drive it then all cars would have electric pumps. A
friend has one on his dry sumped Hayabusa and it put out the same power on the rollers as any other stock busa would.
[Edited on 15/12/05 by ChrisGamlin]
I was under the impression that they are quite reliable. I have read a few reviews and they were regarded as 'the next big thing' but
perhaps their longevity has yet to be proved. I think they have a two year guarantee which is reassuring.
They also did a rolling road test on a 2.0 Duratec and achieved a 7-10 hp gain and 5% fuel saving when compared to the same engine with a conventional
water pump fitted. Quite a bit smaller than the 20hp claimed by the distributor but significant none the less.
I suppose time will tell .... coz mine arrives tomorrow
I have to admit, I find even 5bhp a surprisingly large amount of power to drive a small water pump. Perahps they tested it with the cooling system full of treacle?
Not quite up there with an LMP car but I did fit one to a supercharged mk1 MR2.
It worked quite well for the time it was fitted and gained 5BHP on the rollers.
Originally posted by tadltd
As Prodrive discovered, they do release more engine power because they eliminate the parasitic losses associated with an engine driven pump - it takes engine power to drive any ancillary (e.g. alternator , AC compressor, supercharger, power steering pump [hence electric power steering], water pump, etc.), so if you can eliminate one of these power drains you claw back power. A water pump can drain a LOT of power when the engine is operating at high speed.
It is the intelligent use that is the key. As other people have said, the mechanical water pump can only be a design compromise - it has to provide
enough flow for all conditions regardless of the engine's true needs. A hyperthetical case for example, when the engine is redlining on the track
the pump is absorbing a suprisingly large amount of power to operate at a ridiculously high flow rate. The electric pump will often operate
after this power surge as it monitors the heat output and not the power output. Therefore (taking things to the extreme) the engine is able to
produce more power when required and can cool down during braking.
Obviously the power required by both systems has to come from the engine, and the efficiency ratios are quite different, but the real difference is
when the power is absorbed.
I was under the impression that they are quite reliable. I have read a few reviews and they were regarded as 'the next big thing' but perhaps their longevity has yet to be proved. I think they have a two year guarantee which is reassuring.
They also did a rolling road test on a 2.0 Duratec and achieved a 7-10 hp gain and 5% fuel saving when compared to the same engine with a conventional water pump fitted. Quite a bit smaller than the 20hp claimed by the distributor but significant none the less.
I suppose time will tell .... coz mine arrives tomorrow![]()
Agreed, it sounds a bit fishy when they say
"As a courtesy, we showed Davies Craig the test results that we had found.Unfortunately, because of their responses, we now feel that we
cannot bring these stories to you.Thinly veiled threats of legal action from large companies can do that.....
This review was over five years agobut to be fair, they might not have been able to publish their results for any number of reasons. Having
said that, I still can't find any bad reviews for the EWP and everything I've read seems to be very favourable.
It's worth noting that the box I received yesterday states in big letters "Generation III with Ceramic Seal" so maybe they HAD a
quality issue in the past and have now revised the design - a lot can happen in five years. It also clearly states a two year guarantee applies which
in my book says they must be confident in their product.
[Edited on 17-12-05 by RazMan]
In reply to the original question, I put mine as low as possible, and close to the engine, connected to push first into the motor, and the motor
outlet goes to the rad.
The bottom feed from the header tank goes into a T just before the water pump to ensure constant head of water at the pump. I also connected a top
bleed from the rad to the top of the header.
The system self bleeds perfectly and seem to work well, although I have only conducted idle tests so far.
Fred WB
Excellent advice Fred - that's exactly the info I need to design my cooling setup, even if if it did take 20 posts to get there
The only thing I don't quite understand is....
Originally posted by Fred W B
I also connected a top bleed from the rad to the top of the header.
OEMs can be notoriously slow at adopting new ideas or changing traditional ways of doing things, look how long it took Ford and Vauxhall to start
fitting 5 speed gearboxes to all of their cars despite the euoropean and Jap stuff having had it as standard for years.
Maybe the Davies Craig unit has reliability issues, these will probably be cured. And if Bosch have started making them for BMW that can only be good
news for Locosters as it means scrappies will start getting them in
They will probably appear on production cars over the next 5-10 years, as
electric power steering pumps are starting to do now. With ever-tightening emissions laws the ability to speed engine warm-up times has to be
attractive for manufacturers.
Remember, when someone else says they've had reliability issues and blames a piece of equipment you have top assume they fitted it correctly and
ran it correctly. People are wonderful for blaming new kit for not working when actually it was because they didn't read the manual or fitted it
hamfistedly/incorrectly.
I'll stick with the mech pump on my Zetec for its initial build, then look at a D.C. when I've some spare pennies.
Here's my draft layout - the heater will be fed by a single 15mm pipe directly from the pump (as there is no thermostat)
Any suggestions?
Raz man - Yes, the bleed is from the top of the rad all the way back to the top of the header tank.
You can see it in some of the photos in the thread link below, as I posted in your thread re alloy/rubber pipes.
I also used a swirl pot , with the top bled back to the header tank.
This layout is as recommended by Carrol Smith, in Prepare to Win and Engineer to Win (if anyone else has those books did you notice how the two
diagram's differ? - seems Carrol changed his mind between writing the two books)
Most important point - put the header tank as high as possible. The header tank cap is the only opening I have in the system.
Another point that that he makes, and that makes sense to me, is to have a restrictor in the engine outlet, to keep the block pressure up. On most
engines this is usually the thermostat, so I have retained mine, but with three 6 mm holes drilled in it to allow some flow when it is closed.
I have spent quite a lot of time on the net researching re the DCWP, and for every report you see that has used the DCWP successfully, you will find 5
that state that they know of, or have heard of, or once met a bloke who, had a problem with one. But never first hand knowledge on problems. So will
see for myself once on the road.
Fred WB
http://www.locostbuilders.co.uk/viewthread.php?tid=30565
[Edited on 18/12/05 by Fred W B]
The feed should go to the top of the radiator, and the heater 't'd' into the feed (to get the most heat from the coolant). The heater will also act as a small heat exchanger meaning there's less heat in the coolant at the radiator.
Fred, I know that Davies Craig recommend taking out the thermostat when using their pump but the heater will probably take ages to warm up so I was
considering inserting one in line too, also with some extra holes, to keep some flow going. Now you mention it, it makes sense to keep some block
pressure so it looks like a thermostat is a good idea all round.
The header tank will go in almost the same position yours is mounted and I will incorporate the bleed tube which also makes good sense. I'm not
sure about the swirl pot so I will see how things go and test the system when the car is running.
Steve, I was under the impression that feeding the top of the rad will encourage air locks. My diagram shows it fed from the bottom with the heater
tee'd from the pump to maximise on pressure to get the heater warmed up quicker (it's a theory anyway) The Duratec has a separate water
jacket around the oil filter which I have taken out of circuit for simplicity but I might re-use it if I feel the need - I would put this in the
circuit between pump and heater to get as much heat as possible, shutting it off with a valve (also in the feed) when not required. I can then use the
heater for cold air flow in the summer.
Here's my revised version - now in glowing colour
[Edited on 18-12-05 by RazMan]
Having worked as a cooling systems engineer prior to starting TAD, I now have oodles of experience in designing and engineering cooling systems that
work. If you drive a Ford B-car (i.e. Fiesta size) you'll see some of my work under the bonnet.
In fact, if you take a quick look under the bonnets of most other cars you'll see a similar set-up, i.e. hot coolant into the top of the
radiator. Motorbikes use the same set-up.
Trust me, I know what I'm talking about.
[Edited on 18/12/05 by tadltd]
Now you mention it, I do recall the top hose in some of my cars being the feed. I'm sure there must be a logical reason but I am no systems
engineer (just a graphic designer) so I will take your word for it Steve
So if I simply reverse the rad connections, do I just run the heater in parallel across the pipes at the rad end? I am a little concerned about the
flow taking the path of least resistance (presumeably the radiator) and leaving me with cold feet!
*edit* I think I understand the most efficient way for the heater plumbing now but correct me if I'm wrong....
The outlet from the block goes to a tee - one side to a thermostat and the other to the heater valve. This will ensure that most of the available heat
during the warmup phase is directed through the heater. When the thermostat opens fully, most of the flow will then go through the rad but there
should still be sufficient flow through the heater due to the pressure differential in the outlet tee caused by the thermostat.
Am I close?
Got it now - my O level physics knowledge must have deserted me (was a long time ago though
Here's my latest revision taking all the advice into account...
I don;t wantto be a pedantic git but the take off to the heater should come beforethe thermostat. Usuallyu there is a take off on the engine block or
some other means.
Doing it like that will mena you have hot air before the thermostat opens... not a big deal but nicer in winter.
But isn't that the idea? Maybe my drawing isn't that clear - it is meant to look as though it is tee'd of first. If the heater was
plumbed into the same feed as the rad it will only get heat at the same time. Otherwise I might as well just run both in parallel with each other - it
would shorten the plumbing though.
[Edited on 19-12-05 by RazMan]
You should have heater inlet and outlet spigots on the engine block, why don't you just use those?
The idea of the heater being in the engine cooling loop is to give you hot air more quickly because it will receive the coolant before the radiator,
i.e. prior to the 'stat opening.
Didn't you retain the water pump housing, though? To block the hole? I guess not if there's no spigot for the heater return?
No, the water pump is a completely independent unit on the V6. It is connected only by hoses to the rest of the engine and even the thermostat is an in-line jobby. It was therefore a simple case of unbolting it and removing the pump, pulley & belt - tidies up the engine bay too.
