after reading the following in another topic in this forum
Originally posted by dave dickson
I saw a race series at the local track a while back with a load of minis which were converted to rwd. The engine was mounted longitudinaly, with the driveshaft now facing forwards welded to the subframe to stop it turning. the diff then transfered all the power to the other shaft, which was lengthened and coupled to a rear axle of unknown origins.
It all loooked a bit bodged, but they looked like an absolute hoot to drive.
I think on the old metro 6r4 rally cars the transmission was similar to that of a land rover. Engine and gearbox in the middle connected to a diff which is connected by two drive shafts to a diff at the front and back. I think?
Originally posted by cornishrob
Has anyone ever heard of someone using a transverse 2wd engine and gearbox pairing to split power from a longitudinally mid mounted position to power all four wheels?
I think audi's are constant 4 wheel drive.
They have a engine slung in front of the front wheels and what is basically a normal gear box driving the back wheels. However, it also has two drive
shafts coming out of the side to drive the front wheels.
Above idea has been discussed before. The problem is you already have your final drive reduction before what is now your centre diff. You'd
need to source (more like make yourself) 1:1 diffs for the front and rear. Otherwise a very nice idea.
Audi A3 and TT are a part time 4WD system borrowed from VW - essentially front wheel drive until slip occurs. Conversely a VW passatt is a full on
quattro.
Here's how a 6R4 works by the way...
Liam
i have the audi S3 which is a full quattro but is the same set up as the a3 and tt standardish fwd gearbox with transfer box bolted on which sends the drive too the rear diff. The difference with the S3 is that its intelligent and sends the power to the wheels with grip.
As Liam says the problem is the final drive ratio, i.e. needing 1:1 (ish) diff ratio on either end.
I've heard that some of the sporting trials guys (the tiny things with bike front wheels, and a passenger who bounces up and down
) weld the
diff of a transverse engine and use one long driveshaft to a live axle to get an insanely low ratio so they can climb muddy hills better.
[Edited on 18/12/05 by iank]
Sixedup, im not entirely sure on the new VAG 4x4 systems, But they do have transverse front mounted engines much like the celica GT4 and Mitsubishi
evo. where the drive from one driveshaft is put through a transfur box mounted to the gearbox and then connects to the prop. I dont know however how
they can get this to stop power going to the rear wheels.
On the subject i would rather use ATB differentials over LS as it would act more like the traction control system in the skyline GTR's putting
the power to the wheels with traction.
Oliver, much like the 4x4 cosworths and subaru imprezas mounted longitudinally, a far better way imo but has a lot of weight in the nose.
With the subject of dif ratios i see the point but dont understand fully. I take it using a dif sorced from a sierra would cause a furthur reduction
in final drive?
don't like it give me my old quattro any day
With the subject of dif ratios i see the point but dont understand fully. I take it using a dif sorced from a sierra would cause a furthur reduction in final drive?
So it's more like a caviler or calibra 4x4 with an abnormal diff in the back of the gearbox and a transfer bos in one side with a hollow shaft for the drive out to the right wheel an two clutches on the transfer box to control the drive to the rear wheels.(yes i did have a mate with a cavy 4x4 turbo which had problems in the transfer box).don't like it give me my old quattro any day
Mike
My celica GT4 was permament 4x4 with a transverse engine in the front, 70% rear 30% front split on power, tends to handle more sideways than the
scoobs and evos and fantastic to drive, i miss it so much
, but better things to come.
I see the problem with the differentials then and custom items would need to be used to make it faster as such.
