k16 rover 416si
tim windmill - 20/12/05 at 12:40 PM
just done head gasket on tin top 416 si, skimmed head new bolts gaskets etc.ticks over perfectly and revs smoothly to red line whilst stationery.problem is when the car is driven it cuts out at junctions and will not idle. checked for leaks on inlet manifold and seems ok also checked idle control valve again seems ok. any body got any ideas?
rusty nuts - 20/12/05 at 12:52 PM
Probably worth cleaning the idle speed control valve with carb cleaner, they sometimes look OK but it helps to clean them . Also how did you check for air leaks? try using WD40 sprayed around manifold etc , revs will sometimes rise if leak is found . rechceck all sensor wiring . HTH
rayward - 20/12/05 at 12:54 PM
is the TPS OK?,
Ray
britishtrident - 20/12/05 at 01:55 PM
Starting with the items that don't cost anything to fix.
Check the pipe between the inlet manifold and MEMS ecu is clear be very carful disconnect at both ends before blowing through NB the connector on the ECU is brittle and gets more fragile with age.
Also check the earth for the ecu is clean and making good firm contact-- the thread on the bolts tend to become coil bound so a new spring washer and bolt helps. It is located on the bonnet landing panel adjacent to the left headlamp.
Check the temperature transmitter are connected correctly the one for the ECU has two connections the one for the instrument cluster only one wire.
However my prime suspect is the crank sensor on the older k series with the sensor at the back of the engine these tend to give trouble with iffy connections after major engine or gear box work is done. Usual symptoms are cutting out at idle or failure to start.
tim windmill - 20/12/05 at 06:47 PM
thanks for you replies i will get to work on checking these tomorrow
