vacuum on dizzy
scutter - 21/2/03 at 05:07 PM
Gents, just about to fit the dizzy to the engine(X-flow, twin40s) and was wondering what or where to fit the vacuum hose to. The dizzy is an electronic one out of the valencia engine.
As always any advice welcomed. Dan.
jollygreengiant - 21/2/03 at 11:28 PM
Can't fit a vaccuum take off to any cylinders if running twin 40's cos if you go into just 1 cylider you get such an erratic vaccuum pulse that the vaccuum unit goes tits up very quickly (gets vibrated to death & takes a matter of days) & if you tap into multiple barrels then you effectively create an air leak across the manifold and get incorrect fueling. So just fit the dizzy & forget about the vaccuum advance.
Enjoy.
kingr - 23/2/03 at 02:23 PM
Doesn't that mess up your ignition timing?
Kingr
locodude - 23/2/03 at 07:38 PM
Check out Dave Andrews site for tips on how to modify distributors or bite the bullet and buy a modified one from Aldon or Vulcan. I supplied engine specs and a dizzy (Lucas type) to Aldon and they remapped it and de-vacuumed it for about £65.
scutter - 23/2/03 at 09:11 PM
Cheers All, will contact aldon in the morning.
Dan
