I've sorted out the accelerator cable by making small brass ferrules (?) to hold the cable in place and a small adjustable bump stop so the pedal
rests in position. The bump stop has a buffer made from a piece of radiator hose!
accelerator pedal bump stop
To reduce the angle through which the accelerator cable goes, I made a small pulley for the cable.
accelerator cable pulley
I don't forsee any problems with this but all linkages I have seen use a rod; my set up has a cable running in a curved guide.
If I get enthusiastic I might look into replacing the pulley with a pivoting lever to pull on a rod, later ....
Just wondering if anyone has comments on the pulley system?
Lastly I welded two plates to the side of the chasis for the ignition coil. It now sits in an air flow past the raditor so it should be happier as
previously it was bolted to the cylinder head!!!!?!?!?!?
[img][/img]
Bit of a kink where the cable goes through the bluckhead (next to master cyclinder)... Might be and idea to ensure this is always straight....
you might find that the ratio between pedal movement and the opening of the carb is a bit high and make controling the engine speed a bit
difficult.
Keith
Suffolk
Originally posted by Schrodinger
you might find that the ratio between pedal movement and the opening of the carb is a bit high and make controling the engine speed a bit difficult.
I'd consider a split pin over the green wire
I wouldn't be surprised if the cable snaps where it's welded to the linkage as this little bit will be constantly flexing on a short
radius...a better, more flexible solution would be better....especially one that means you can change the cable at the roadside in the middle of
France after a quick trip to Euromarche...
[Edited on 4/1/06 by stevebubs]
By using a rod linkage, it usually means that the further the pedal is pressed the less the linkage moves. If that makes sense. The lever goes 'over center' so moves the butterflies less.
Originally posted by stevebubs
I wouldn't be surprised if the cable snaps where it's welded to the linkage as this little bit will be constantly flexing on a short radius...a better,
Perhaps one of these would work?
From Rally Design
cheers for comments
straight....
yeah, I cut the cable too short; will need to make a slightly longer bulkhead connector.
bit difficult.
no probs. there; quite the opposite in fact; compared with volvo and LR and distances of pedal travel are:
V = 60 mm
LR = 57 mm
K = 83!!
ok
on a short radius...a better, more flexible solution would be better....
the weld is for a small piece of metal to connect linkage to front carb not the wire. The wire passes behind it and round a circular guide
- photo makes it look like wire is welded.
The pulley was made reasonably big to avoid having a tight bend for the wire. I will be looking to replace the circular guide so the throttle can be
operate by a rod and lever that would also be asjustable to set the ratio so reduce pedal travel a bit but that is for later..,,.... .
