Has anybody used a Gear reduction starter motor.
I am looking at trying to improve starting my xflow as the original one does struggles to start . Would this improve significantly or is there a
cheaper solution i can get that would be easy to fit ?
First found this in a burton catalogue for about £170 i think.
my mate bought one for his mk1 escort he has a 1700 xflow and the standard starter wouldnt turn it enough to fire. his gear reduction starter turns it easily now. i think it was from h and h ignition solutions
Go to www.lynxae.co.uk and speak to Jon Lee. He sells all types of reduction starter motors. They are also lighter than standard and use less current. They can therefore be used on cars with smaller batteries. I think that they are around £120-140 brand new.
whyt is that?
a) is it the motor not powerful enough?
b) is motor on its way out?
c) is battery on its way out?
d) is battery unable to supply oompf?
if you jump start with second battery in parrallel, that would rule out c) and or d).
If the jump battery is bigger, try fitting that; then rules out d)
If that is the case, fit bigger capacity battery - cheapest solution but has wieght/size disadvantage.
Are you battery leads nice and fat, properly terminated and making good contacts? Even cheaper to fix.
What battery do you have fitted?
electronic ignition will help starting - what have you got?
Originally posted by 02GF74
whyt is that?
I got 'gear' starter motor exchanged for £80 at my local motor shop (the box has AUTOELECTRO written on). Note that it had to be exchanged
because the wee epicyclic gearbox in it was wrecked - all the teeth fell out on examination - looked as though it spun up OK at the scrapyard where it
was a fiver.
So I think they're much better starter motors but there's an extra set of things to go wrong in 'em so watch out with scrapyard
purchases!
cheers
Bob
whyt is that?
