Here's a pic of the cut and shut RV 8 plenum (now twin) and shortened manifold.
Simon
looks just like the one in hardcastles book
how about a big chargecooler in the scuttle area to cut down on your pipe runs? i told you ive got some
centre outlet p6 manifolds didnt i?
froggy,
Yeah - you mentioned the P6 manifolds - any chance of some pics and rough dimensions (ie how far out from block they come) and let me know what
you'll want for them (I'm near Tunbridge Wells if you need to find out postage), though I'm toying with the idea of making manifolds
from butt weld pipe.
Let's see what's cheapest
Simon
Simon
I posted this yesterday - 2 P6s locally, though I don't know what engines (if any!) are in them.
http://www.locostbuilders.co.uk/viewthread.php?tid=43511
Originally posted by Simon
froggy,
Yeah - you mentioned the P6 manifolds - any chance of some pics and rough dimensions (ie how far out from block they come) and let me know what you'll want for them (I'm near Tunbridge Wells if you need to find out postage), though I'm toying with the idea of making manifolds from butt weld pipe.
Let's see what's cheapest![]()
Simon
Simon
Hell Simon
that looks like it will let the bugger breath (or should that be fed
). makes my westfield plenum looking like F3 intake restictor.
Have any of you V8 boys thought about running the plenum insulation plate shown in PPC i know mine suffers from heat transfer.
Keep us posted with progress
Regards
Agriv8
[Edited on 25/4/06 by Agriv8]
simon., il def post some pics and dims tomorrow
How come you have made it with inlets on both sides as opposed to the Rover twin plenum which had them both on the same side?
Looks good though!
Simon,
saw that, but forgot about it- oops
Andy,
One turbo each side
froggy,
Cheers.
NS
Here
- though it needs a couple more welds where I missed
Got to mirror polish it next, which I'm not looking forward to
Simon
ahh see it now!
VERY nice job!
hope your patience holds for the polishing!
Simon / Froggy,
IMHO you will be wasting time with P6 manifolds (assuming they are standard cast iron ones).
You've spent all that time & effort virtually doubling your intake, so you will need to make some decent headers to get it out the other end.
Check the Hardcastle book, but I think the only half decent cast manifolds are much later ones (twin secondaries, etc). Apart from Range Rover / LRV8,
P6s were the least powerful production Rover, so I don't think the manifolds can be too good.
[Edited on 26/4/06 by TL]
heres the pics, the manifolds are 170mm deep to the outlet flange measured from the outer edge of the bolt holes and stick out about 80mm from port
face to the outer edge of the downpipe flange
[Edited on 26/4/06 by froggy]
and another
if you want a lend of this let me know ,full of good stuff
Froggy,
They look grand
Let me know what you want for them, incl postage (via U2U if required).
TL - They may not be the best flowing, but they are the right shape (and similar to what I would make anyway - dictated by space). I'm sure
someone could confirm or otherwise that n/a flow is different to forced induction requirements.
Re the book - is it any good. Just been reading review on amazon, and they're quite mixed. If you say it's ok, I may order meself a
copy
Simon
[Edited on 26/4/06 by Simon]
corky bells words"when a choice exists as to a tub size, always opt for the smaller, to keep gas velocities high" thats on manifolds. do you
want to lend the book too? as for the price cover the postage and buy me a pint if your at stoneleigh
big up the v8 massive!!!
froggy,
I'm not going to be able to get to Stoneleigh
I'll order a copy of the book - that quote you gave was the exact same argument I used on someone t'other day
- thanks for offer
though.
If you find out a postage cost and U2U me your address, I'll get as cheque/p.o. off to you.
Simon
Froggy you at stoneleigh ?
If so Ill be the tall lanky git with short hair hanging around the MNR Stand, Pop over and say hello as we need to sort out arangements for that
diff
Regards
Agriv8
Froggy,
I hadn't realised that you were turboing (I should have read the "chargecooler" reference and your "one turbo each side"
reply - that would have been a bit of a give away. Must learn to read proper)
Anyway, you're absolutely right. I don't know the specifics, but header shape isn't nearly as important on charged engines. Sorry for
ever doubting you!
Just had to post -
Froggy, thanks for the manifolds - arrived at work on Saturday, addressed to
Mr Turbo Nutter, most amusing
Anyway, got a bit bored today, and had a spare half hour, so did some mocking up.
Still waiting for my flanges to be cut, but you get the idea.
Simon
[Edited on 7/5/06 by Simon]
