Another question from me...
I currently have a 38DGMS carb to bolt onto my pinto.
Potentially I can get a pair of 40DHLAs. According to the jetting calculator on Dave Andrews website 40's will give me a maximum of 6000-6250rpm
peak power with 36-37mm chokes. (more than enough with a std pinto bottom end?!)
Question is, is it worth upgrading to a pair of 40DHLAs over my 38DGMS? If so what advantages could I expect?
Hmmm the noise of 40's
Not sure about Twin 40DHLAs but I think Twin 40 DCOE's only usually have a 32mm choke and from what I remember you either can't change them
because it lessens the venturi effect or it was certainly expencive.
[Edited on 28/4/06 by MkIndy7]
Much more kudos (or is that an aftershave?).
And girls will swoon at the sight of your exposed trumpets!
Get bike carbs.
- Better fuel economy
- Better performance
- Better sound
- Easier to setup
- Stay on tune better
Can you tell I really like my R1 carbs?
Bike Carbs 1
[Edited on 28/4/06 by andyharding]
Do the bike carbs sound nice Andy??
Cant wait to get mine on.
Go on David - fit bke carbs and megajolt (after SVA???).
Chokes are available upto 36mm for 40DCOEs and 37mm for 40DHLAs. Aux venturis are the expensive bit from what i can gather.
I must say I like the idea of bike carbs. But I would like to hear some rolling road results comparing a bike carbed set up to a twin carb setup if i
was going to go that way...
Darren, megajolt is beyond me at the moment. I like to keep it simple, give me more chance of fixing it at the side of the road if it conks out
Any more input welcome
I bought twin DHLA 40's that have been set up for a 2.0l pinto and I think they have 34mm chokes and 36mm is a maximum. Don't people say a
2.0l is best with 45's anyway.
Having read the recent Bogg Bros thread I could well be going the R1 carb route now. I've been watching a few go on EBAY and they seem to go
around the £100 mark so cheaper to buy than Webbortos too.
By the time I've bought a manifold, linkages and ram pipes I'll probably have spent more than the £300 quoted on here for a package from
Boggs.
If I hadn't got them in the garage I'd definitely go the R1 carb route as they seem to do more for similar money.
Have a quick read of this its a zetec with gsxr750 tbs though, but it might help
http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?s=c7315d37dd6c1c9e59050d2f068a0452;act=ST;f=3;t=39625
i'm already on 40's but i think bike bits are the way to go
Andy do they really sound better ? i've never heard them run, but lots of people are saying good things
Finally got around to uploading the video I made just after fitting the bike carbs (ignore the bodged throttle cable).
Warning: it's 90BM so if you haven't got broadbeans you should have.
http://www.inetc.co.uk/download/MVI_7763.AVI
I'll stick with my 40's, if i did'nt already have them i'd probley go with the bike bits.
Ps nice vid, and good upgrade
