Tricky one this guys,
How do you bend exhaust pipes when there already made?
The lolocost manifold I've got seems to be sitting a bit high, I've moved the engine to the correct position so it fits under the
bonnet.
There's about 2" clearance between the exhaust and the bay cross brace.
All help gratefully recieved. Dan.
Hi Scutter
Personal opinion only:
If it was mine I wouldn't even try bending anything at the manifold end having got it as far as you have!
I'd concentrate on the pipe between the collector and the silencer with the silencer in it's final position. Maybe cut and re-weld the pipe
ends and/or splice in some bends, which I'd buy ready made.
So far as I know, given certain general points of exhaust tuning efficiency (e.g. length, diameter and bend radii) then for road use the layout is
largely a matter of personal preference.
Perhaps I'm not such a perfectionist as you but the set up in the photo looks really good to me!
I only wonder what's hiding behing the towel?
And did you transport the project up to Leuchars?
cheers
Dave
[Edited on 13/4/03 by Dave Ashurst]
Cheers Dave, the move to leuchars is in June, the towel is a mod I made to soak up all the oil leaks from the X-flow
Most ro**n h**ds that I've seen have an exhaust like this, not suprising really with it being a lolocost manifold.
Will leave as is then and concentrate on getting it on it's wheels.
Thanks Dan.
Ha Ha You think your funny saying that now, but you'll be in big trouble with your mum when you start the engine.
Hush, she no know it's missing
Dan.
I have a R***n H**d and I've got the same problem (because I didn't want to mount the engine at too much of a slant). Any other advice on bending the pipe?
On the RHE collector section (where the 4 pipes go into 1), the metal is a bit thinner than the pipework.
I found that, with a little brute force and at the cost of slightly crumpling the collector, I could get the tail pipe in the right position. The
damage to the collector was minimal and it faces the body so won't be too visible. The exhaust is now just right.
(Usual caveats apply)
PS, mine was pointing down slightly too, and sticking out too far. Sorted now, though.
[Edited on 23/4/03 by Jon Bradbury]
Jon, Any chance of a pic or two
just to give us an idea.
Cheers Dan.
wots a rodin pood?????
Originally posted by scutter
Jon, Any chance of a pic or twojust to give us an idea.
Cheers Dan.
This might happen because the pipes are a bit soft - not to worry because you'll be covering it with an SVA compliant exhaust clamp.
[Edited on 24/4/03 by Jon Bradbury]
..actually not as bad as it looks because it faces the bodywork and in any case because its all shiny its hard to make out.
Jon, Many thanks for that.
I think we locosters are resourceful because we have to be, I mean no one else is going to do it for us.
Thanks once again Dan.
