Is anyone running one in there kit car yet, Ive seen cosworth turbos and 200sx engines fitted but not this one. Im currently running one in My Clio
16V which is pushing around 279Bhp lag free so i think it would be perfect for the Luego.
Any ideas lads.
Be the first and go for it. If you have fitted one in a clio you can fit one in a Seven. This is highly rated modern engine which can pruduce huge
power
Quite a few running around in Lotus Elises to good effect also.
Presume the Clio and the elise boys are all running it transverse on the VAG gearbox.
So the questions are really:
Is there an in-line gearbox fitment that can be made to work for sane money (doubt a type 9 would be up to it even if you can get a bellhousing).
Will it fit under the bonnet - with all the turbo gubbins and intercooler. Will getting rid of all that heat be a challenge?
Exhaust will need to be a special as well.
only issue is getting gearbox to mate to it.
Duko, durrk, du........ oh that sweedish seven manufacture has figured it out, but they aren't keen to let people know.
i had the 225bhp TT and the oil pump went at 10k, so new engine under waranty then it went again at 40k no waranty so new engine (big£££) so i sold it
to wait for it............ a hairdresser
[Edited on 10/7/06 by graememk]
donkervoort use a bellhousing i believe. was talk about it quite recently and has been many times before - a search might help. I recall someone
mentioning it has the clutch/flywheel on the gearbox side rather than the engine side or something odd?!
Ned.
Someone on the seven's list looked into it as well. Got someone else to speak to the factory as i recall and they aren't prepared to sell
the adaptor bits without a whole car.
Think he found the company that did the adaptor bits as well, but they didn't want to annoy their major customer by dealing direct.
is this it?
Also this link has a UK type 9 gearbox fettler who modifies them to take 500NM of torque (whatever that is )
http://www.donkervoort.info/Tech%20tips.htm
two views belowImage deleted by owner
tight isnt it?Image deleted by owner
tighter than a gnats chuff!!
Looks like one of those engines where any/every job is/can be completed with only one tool
a credit card.
Certainly an engineering challenge to get it all in there, but I can't get away from my scepticism (spelling?) over turbo charged power delivery
in a lightweight 7 style car. Obviously I've never driven one, but I just imagine it being too on/off when the turbo spools up to pressure - I
guess engine/turbo choice and set-up would play a big part though.
I guess the VAG unit must be pretty readily available by now and not ridiculously expensive.
Be easier to use it with an Audi transaxle in a mid engine set-up though
The 1.8T engines do still fetch a fair bit of cash considering the'yre in everything on the road at the moment, you're looking at well over
1k for a 180/225bhp version. That said, they are cracking engines. Very early ones had problems with failing coilpacks and weak water pump impellers,
but certainly most will have had their coilpacks replaced by now. Other than that they're pretty reliable, no horror stories about unless you do
something silly like whack up the boost and hope for the best.
As has been mentioned getting it mated to a gearbox is the tricky bit, VAG don't do any RWD 4 cylinders. Apart from Donkevoort there is Estfield
who use a Lada gearbox, but apparently that isnt up to much above 150bhp. The porsche 924/944 transaxle would probably work but the whole gearbox is
on the back axle (it's a fwd gearbox with a torque tube attaching it to the engine in front) so will be a squeeze in a 7. The LT van might be
suitable, I can't find out if the 6 cylinder diesel engines have the same bellhousing bolt pattern as the 4cyl engines though. Other problem is
the clutch, VAG make them backwards with the pressure plate bolted to the crank and the flywheel on top. Clutch is actuated by a pushrod coming
through the centre of the input shaft.
One day soon someone is going to do it though, and I think they'll be on to a winner with it
thanks for the replys guys, Much apreciated. i wll probably end up making a bellhousing for it using an old gearbox like i did for the 1.6 Sigma but
the plate might be a bit of an isuee. i no the local breakers which is handy aswell.
As for the power delivery its very good in mine, no lag to worry about and bags of torque which im worried may kill the type9 box bot never mind,
here's my power graph
http://i13.photobucket.com/albums/a282/FlansS14/File0006.jpg
ill pick the engine up next week and have a look and "trial fit"
fingers crossed
keep us up to date with your build!
Isin't there any Vag vans or people carriers that are RWD, the transporter etc?
Suppose they'd probably be a biton the big side though.
Originally posted by FlansS14
thanks for the replys guys, Much apreciated. i wll probably end up making a bellhousing for it using an old gearbox like i did for the 1.6 Sigma but the plate might be a bit of an isuee. i no the local breakers which is handy aswell.![]()
As for the power delivery its very good in mine, no lag to worry about and bags of torque which im worried may kill the type9 box bot never mind, here's my power graph
ill pick the engine up next week and have a look and "trial fit"![]()
fingers crossed![]()
As megatron says really - I'm concerned about my 170lb/ft killing the type 9 and you have 100lb/ft more than me! I suggest you use an alternative
box such as a t5 out of a 2wd cossie for that sort of power.
Ned.
Actually the clutch on these engines is a conventional type, it was the older Golfs that had the back to front clutch.
As a general rule if its transverse engined and has a rod type gear linkage it's a back to front clutch (Mk1, Mk2 & some Mk3 Golfs and
derivatives).
If it's transverse with a cable change box (as this engine would have) or in line (Passat or Audi A4 etc.) then it's a conventional type
clutch.
Hope this helps
i think a T5 box would be best , you can still buy the new aka the tremec tko 600 , an adapter plate shouldnt be too hard to make .
klracing.se make some vw manifolds and stuff , not sure on adapter plates .
i do know of a company that can punch 10mm steel accurately , if you need some help .
Thanks guys. maybe i should forget the type 9 in that case as im a bit of an "iratic" driver and want to thrash the car on a track. my other
option was a 200sx engine and box but there abit old and BIG. i supose i could mod a 200sx box as there cheap and redily available
i also think it will be hard to get to 280bhp on the std k04 turbo. my clio has an evo intercooler which is pretty big and frontmounted, the luego
chassis is very tight....
going to be interesting.... ?
I have seen your car, I think it was at York drag strip - nice work.
I have been interested in using the 1.8T as a powerplant for a locost. It makes perfect sense really.
If you manage to get a working combination for the gearbox, then I suspect you will be flooded with requests for information
I have heard a rumour that a certain year Volvo 740 diesel used a vw 4 cylinder block and is rear wheel drive. The bolt pattern on VAG 4 cylinder
blocks has not changed since the dawn of time so in theory the volvo box should mount straight up.
Might be worth checking out.
the vw 6 cylinder is the engine in 7/9 series volvo - dont know if it shares the same bellhousing pattern as the 4 cylinders .
Was trying to keep that quiet to make a packet on unused/unloved volvo diesels that have gone past their sell by date
ah right, so there are no 4 cylinder volvo diesels running vag blocks then?
and if the volvos are 6 cylinder, is that the VR block with the 2 banks covered by one head or does it have 2 seperate cylinder heads?
http://www.tigersportscars.nl/Bellhousings.htm
bingo!
You coud use a Porsche 924 bellhosing and torque tube. You would end up with a transaxle (basically Audi gearbox) setup. I have the torque tube and
transaxle out of an early 944. First my plan was to use the Mondeo duratech engine with that combo. The 944 input shaft spline happens to be 1 inch
dia 23 tooth sline. Ideal for Ford clutch setup. But know i do seriously consider the 1.8 t VAG engine option out of a Passat or Audi A4
(longitudinal). It seems that the bellhousing is going to be a bolt on affair.
[Edited on 4/12/06 by street1303]
Originally posted by coxylaad
bingo!
