gear box
jerry - 27/5/03 at 06:20 PM
can any one tell me if the oil pickup pipe needs any mods doing when you chop off an inch off the pinto sump.also i need a remote gear change for the 5 speed sierra box n type i think, theres 3 bolts that hold the gear stick in, any ideas
bob your e mail address seems a bit of a dud, they keep getting sent back .
[Edited on 27/5/03 by jerry]
zetec - 27/5/03 at 06:36 PM
MT75 is easy to mod for moving the gear lever but not too many people use it, I've got info if need be but suspect you are looking at type 9.
chrisg - 27/5/03 at 09:36 PM
Honestly I REALLY did try to avoid this
No, so long as you make a big enough hole in the bottom of the sump for the oil strainer to poke out.
I can resist everything but temptation.
Chris
