Hi all, do any of you know how the pump is fitted originaly on the bike, or does it not matter, I was thinking about the horizontal or vertical angle
like these pics
Jason
[img][/img]
Not sure but is that a fuel injection fuel pump?? Is that right for a pinto?
If not then you can mount it should be mounted horizontally.
Rich.
MIne is mounted horizontally.
Looking again it does look like a non fuel injection pump so as already mentioned it should be mounted horizontally.
FYI if you want to test it then it should pump about 900cc of fuel per minute IIRR.
Rich.
Many Thanks guys
I was starting to think it was one step forward and three backwards again with the build
Jason
Thanks lads
Thats one more question off my list.
