Has anyone used Nissan SR16VE engines in locost's or in other projects? Comments about engine?
The 1.6 L (1596 cc) SR16VE has Nissan's Neo VVL variable valve timing with lift control. It produces 175 PS (129 kW) @7800 rpm and 119 ft.lbf
(161 Nm) @7200 rpm.
[Edited on 28/11/06 by TTK77]
Haven't used one but they are nice engines. Would it bolt to a 200 SX gearbox?
Stu
seen a pic of a similar nissan motor (maybe the same) in a seven, think it was oz or somewhere, certainly not uk.
edit:
found I still had the pic saved on my pc, now uploaded:
http://www.locostbuilders.co.uk/upload/2ml_engine_bay_sept03.jpg
no more info other than the pic I downloaded years ago from somewhere, maybe a google or image search on the filename which i think is original may
throw up where i got it from...
Ned.
[Edited on 28/11/06 by ned]
brilliant engine,
I've had a drive in a sunny with that engine once, very quick indeed.
the only one mounted in a kit would be Bill sherwoods Mallock racingcar.
grtz Thomas
