I've got most of my loom wired up. The wipers now park, relays wired in for the headlights, fan, horn etc. However, I'm wireing up the
indicators and hazard switch and cannot seem to get anything to work. I haven't wired in the flasher units yet as I have no idea how to. All the
lights operate as they should except for the "flashing". Been hung up on this for ages, any help/sketches would be really appreciated.
Many thanks, Ian.
Err, you are in the engine section m8...
But anyways, what type system are you using, i.e. is it using one flasher relay, or using one for the indicators, and one for the hazards?
Errr ...... finger trouble!! Will move this to the right section. I have two different relays, both with two connections each, but willing to
change if it helps!
