zx 600 carbs
darrenga - 20/3/07 at 01:56 PM
coozer - 20/3/07 at 02:01 PM
Should be OK. what size is the inlet diameter there? 36-38mm should be fine. Webers would have a smaller choke.
40~42mm would be much better, using zzr1100 on my zetec.
darrenga - 20/3/07 at 02:03 PM
Mr Whippy - 20/3/07 at 02:12 PM
I wonder how easy it would be to get different jets to suit the engine size?
Peteff - 20/3/07 at 05:08 PM
As easy as buying a set of indexed drill bits
jacko - 20/3/07 at 05:18 PM
Hi I have zx9r carbs fitted to a 20l pinto there 41mm chokes and the jets where drilled out to 1.7 mm
try doing a serch about this subject
Jacko
