Duratec twin turbo
goodall - 22/3/07 at 10:38 AM
how much power would that give and how hard would the air inlet system be to make?
NS Dev - 22/3/07 at 10:45 AM
eh and why???????
Do you mean v6 or 4 cyl?
On a 4 cyl....pointless
On the v6, great, look at noble, 400hp ish but expect the work to get the engine suited for the turbos to cost a lot more than the base engine, it won't be bolt-on!!!
SaveTheDodo - 22/3/07 at 10:45 AM
Why bother??
takumi - 22/3/07 at 11:01 AM
Why not just use the
Mazda 2.3L Turbo engine to start with as its the same as a Duratec - ford rebadge it..
SaveTheDodo - 22/3/07 at 11:03 AM
He beat me to it....
Remember a Duratec I4s internals are stripped down so much they may all need to be replaced.
Regarding the V6 as that is presumably what you meant, ISTR Nobles now use a different V6 more similar to the S-Type Jag spec not the Mondeo type Duratec V6.
goodall - 22/3/07 at 11:34 AM
the V6 i ment sorry, how much would it all cost to do? just to small turbos noting big
ned - 22/3/07 at 03:35 PM
FWIW you don't have to use turbo's, mountune are getting over 400bhp from a 3ltr jag v6 which is a derivative of the mazda/ford unit
AlphaX - 22/3/07 at 04:46 PM
Ford US got one in a customized production car (dunno which one) and they proudly said they can push 350 out of it. Not much really
goodall - 22/3/07 at 05:05 PM
well id only be wanting 300 at the most probably, otherwise ill have to find a new gearbox because i already have a audi 016 out of a 100
mazmm5 - 23/3/07 at 11:25 AM
The Nissan VG30DETT found in the 1990+ 300ZX twin turbo will meet your requirements in stock trim. 400bhp is easily had with a few basic add-ons. Stock motor can handle 600bhp before pistons need upgrading.
goodall - 23/3/07 at 04:46 PM
nah the engine can be anything really as long as its power full (350bhp at the most), kind a short and plenty full in supply ie not making it too expensive
AlphaX - 24/3/07 at 09:05 PM
that nissan engine isnt very expensive anymore, and its darn good an engine! what about a audi V6 bi-turbo? RS4 spec engine does 385bhp on standard ecu. or the S4 spec does 260 on a standard ecu. Put a stand alone on it and you can get that 350bhp. And those engine are widely available too. had both of them lying around three weeks ago.
